coq-club - Re: [Coq-Club] Does Coq actively convert things to Prop?
chronological Thread
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Does Coq actively convert things to Prop?
  • Date: Tue, 24 Apr 2012 11:53:29 +0200
Wed, 18 Apr 2012 15:31:30 +0200, Stéphane Glondu :
This is not a bug for me, merely an unfortunate convention.
Because this is clearly documented in the manual, this could not be a bug...
...as long as one does not attempt to extract :
https://coq.inria.fr/bugs/show_bug.cgi?id=843
"Type" in this position means "infer", whereas most of the time it means
"a new universe". As far as I know, there is no syntax for "a new
universe" in this position. The "infer" semantics is needed for universe
polymorphism.
As example, the OCaml syntax "_ : _" looks so identical to the Coq syntax "_ : _", that it can happen that one will not look at the semantic of the "_ ≤βδιζ _" conversion rule, described after the Ind-Family in the Coq manual section 4.5.3.
Frédéric
