coq-club - Re: [Coq-Club] Proving large conjunctions?
  • To: Adam Chlipala <adamc AT csail.mit.edu>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Proving large conjunctions?
  • Date: Wed, 18 Jul 2012 22:17:22 +0200
On 07/18/2012 09:48 PM, Adam Chlipala wrote:
Fixpoint truue (n : nat) : Prop :=
match n with
| O => True
| S n' => True /\ truue n'
end.
Fixpoint truuue (n : nat) : Prop :=
match n with
| O => True
| S n' => truue 1000 /\ truuue n'
end.
Goal truuue 100.
compute.
Time split. (* 5 secs *)
Maybe this is not exactly what you want but ou could try to reduce the height of the formula with ad-hoc inductive conjunction.
If you go to the extreme this gives:
Inductive and100
A00 A01 A02 A03 A04 A05 A06 A07 A08 A09
A10 A11 A12 A13 A14 A15 A16 A17 A18 A19
A20 A21 A22 A23 A24 A25 A26 A27 A28 A29
A30 A31 A32 A33 A34 A35 A36 A37 A38 A39
A40 A41 A42 A43 A44 A45 A46 A47 A48 A49
A50 A51 A52 A53 A54 A55 A56 A57 A58 A59
A60 A61 A62 A63 A64 A65 A66 A67 A68 A69
A70 A71 A72 A73 A74 A75 A76 A77 A78 A79
A80 A81 A82 A83 A84 A85 A86 A87 A88 A89
A90 A91 A92 A93 A94 A95 A96 A97 A98 A99 : Prop) : Prop
:= conj100 :
A00 -> A01 -> A02 -> A03 -> A04 -> A05 -> A06 -> A07 -> A08 -> A09 ->
A10 -> A11 -> A12 -> A13 -> A14 -> A15 -> A16 -> A17 -> A18 -> A19 ->
A20 -> A21 -> A22 -> A23 -> A24 -> A25 -> A26 -> A27 -> A28 -> A29 ->
A30 -> A31 -> A32 -> A33 -> A34 -> A35 -> A36 -> A37 -> A38 -> A39 ->
A40 -> A41 -> A42 -> A43 -> A44 -> A45 -> A46 -> A47 -> A48 -> A49 ->
A50 -> A51 -> A52 -> A53 -> A54 -> A55 -> A56 -> A57 -> A58 -> A59 ->
A60 -> A61 -> A62 -> A63 -> A64 -> A65 -> A66 -> A67 -> A68 -> A69 ->
A70 -> A71 -> A72 -> A73 -> A74 -> A75 -> A76 -> A77 -> A78 -> A79 ->
A80 -> A81 -> A82 -> A83 -> A84 -> A85 -> A86 -> A87 -> A88 -> A89 ->
A90 -> A91 -> A92 -> A93 -> A94 -> A95 -> A96 -> A97 -> A98 -> A99 ->
and100
A90 A91 A92 A93 A94 A95 A96 A97 A98 A99.
Goal and100
True True True True True True True True True True
True True True True True True True True True True.
constructor; auto.
Qed.
