- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Proving large conjunctions?
- Date: Thu, 19 Jul 2012 14:42:09 -0400
On 07/19/2012 11:50 AM, Adam Chlipala wrote:
On 07/19/2012 09:59 AM, Frédéric Besson wrote:
I tried to tackle your problem using proof by reflection.
This seems to be significantly faster:
the equivalent of repeat split takes 180s for (truuue 40) ~ 40000 sub-goals but bigger problems trigger a stack overflow.
This is indeed a very interesting idea! Thanks for sharing it.
I find that there are no time savings if I need to do an explicit reification step, converting a "real" conjunction into your [Tree] type. (Though, based on our recent experiences, implementing reification in OCaml would probably lead to an overall speed-up.)
However, I can reformulate the Gallina function generating the goals, so that it outputs [list Prop] instead of just [Prop] with ad-hoc use of conjunction. I manually rearranged one of my largest goals (34-way conjunction, with various nesting patterns) into a [List.Forall] on a [list Prop] and tried your basic method on it. The impact is not huge, but it reduces time from about 7 seconds to about 2 seconds, compared against [repeat (apply List.Forall_nil || apply List.Forall_cons)].
This is still a big enough difference that I will try the reformulation. Thanks again for the idea!
Update on the outcome: I've made the change and tested on my largest goal, which was a 93-way conjunction. The whole proof step now takes less time than the was previously taken by a subset of the conjunctions. Using reflection vs. a naive [repeat constructor] style reduces the running time from about 50 seconds to about 10 seconds.
- [Coq-Club] Proving large conjunctions?, Adam Chlipala, 07/18/2012
- Re: [Coq-Club] Proving large conjunctions?, Laurent Théry, 07/18/2012
- Re: [Coq-Club] Proving large conjunctions?, Adam Chlipala, 07/18/2012
- Re: [Coq-Club] Proving large conjunctions?, Jean Goubault-Larrecq, 07/19/2012
- Re: [Coq-Club] Proving large conjunctions?, Adam Chlipala, 07/19/2012
- Re: [Coq-Club] Proving large conjunctions?, Jason Gross, 07/19/2012
- Re: [Coq-Club] Proving large conjunctions?, Thomas Braibant, 07/19/2012
- Re: [Coq-Club] Proving large conjunctions?, Frédéric Besson, 07/19/2012
- Re: [Coq-Club] Proving large conjunctions?, AUGER Cédric, 07/18/2012
