- To: Frédéric Besson <frederic.besson AT inria.fr>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Proving large conjunctions?
- Date: Thu, 19 Jul 2012 11:50:50 -0400
On 07/19/2012 09:59 AM, Frédéric Besson wrote:
I tried to tackle your problem using proof by reflection.
This seems to be significantly faster:
the equivalent of repeat split takes 180s for (truuue 40) ~ 40000 sub-goals
but bigger problems trigger a stack overflow.
This is indeed a very interesting idea! Thanks for sharing it.
I find that there are no time savings if I need to do an explicit reification step, converting a "real" conjunction into your [Tree] type. (Though, based on our recent experiences, implementing reification in OCaml would probably lead to an overall speed-up.)
However, I can reformulate the Gallina function generating the goals, so that it outputs [list Prop] instead of just [Prop] with ad-hoc use of conjunction. I manually rearranged one of my largest goals (34-way conjunction, with various nesting patterns) into a [List.Forall] on a [list Prop] and tried your basic method on it. The impact is not huge, but it reduces time from about 7 seconds to about 2 seconds, compared against [repeat (apply List.Forall_nil || apply List.Forall_cons)].
This is still a big enough difference that I will try the reformulation. Thanks again for the idea!
Still, 2 seconds to split a 34-way conjunction seems excessive; a standalone tool implemented in OCaml would never take anywhere near that long. Further suggestions on closing this gap would be very welcome.
Inductive Tree : Type :=
| Leaf (A:Prop)
| Node (L:Tree) (R:Tree).
Fixpoint iTree (t : Tree) : Prop :=
match t with
| Leaf A => A
| Node L R => (iTree L) /\ (iTree R)
end.
Fixpoint xflatten (t : Tree) (acc: Prop) : Prop :=
match t with
| Leaf A => A -> acc
| Node L R => xflatten L (xflatten R acc)
end.
Lemma xflatten_split : forall t (p:Prop), (iTree t -> p) -> xflatten t p.
Proof.
induction t.
simpl. tauto.
simpl.
intros.
apply IHt1.
intros.
apply IHt2.
intros.
apply H ; tauto.
Qed.
Lemma flatten_split : forall t, xflatten t (iTree t).
Proof.
intros.
apply xflatten_split ; auto.
Qed.
Fixpoint truueT (n : nat) : Tree :=
match n with
| O => Leaf True
| S n' => Node (Leaf True) (truueT n')
end.
Fixpoint truuueT (n : nat) : Tree :=
match n with
| O => Leaf True
| S n' => Node (truueT 1000) (truuueT n')
end.
Set Silent.
Goal iTree (truuueT 40).
Time generalize (flatten_split (truuueT 40));
set (f := truuueT 40);
generalize (iTree f);
intros ; compute in H; apply H; clear H.
- [Coq-Club] Proving large conjunctions?, Adam Chlipala, 07/18/2012
- Re: [Coq-Club] Proving large conjunctions?, Laurent Théry, 07/18/2012
- Re: [Coq-Club] Proving large conjunctions?, Adam Chlipala, 07/18/2012
- Re: [Coq-Club] Proving large conjunctions?, Jean Goubault-Larrecq, 07/19/2012
- Re: [Coq-Club] Proving large conjunctions?, Adam Chlipala, 07/19/2012
- Re: [Coq-Club] Proving large conjunctions?, Jason Gross, 07/19/2012
- Re: [Coq-Club] Proving large conjunctions?, Thomas Braibant, 07/19/2012
- Re: [Coq-Club] Proving large conjunctions?, Frédéric Besson, 07/19/2012
- Re: [Coq-Club] Proving large conjunctions?, AUGER Cédric, 07/18/2012
