coq-club - Re: [Coq-Club] Proving large conjunctions?
  • To: Jean Goubault-Larrecq <goubault AT lsv.ens-cachan.fr>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Proving large conjunctions?
  • Date: Thu, 19 Jul 2012 08:15:11 -0400
Jean Goubault-Larrecq wrote:
Le 18/07/12 22:36, Adam Chlipala a écrit :
Thanks for the suggestion, but I think this won't help. My conjunctions
are generated programmatically and can get arbitrarily long.
Hi, I had exactly the same problem in 2008, where I was
generating Coq proofs of cryptographic protocols automatically.
I concur with Laurent that variable arity conjunctions (and
disjunctions, too) solved my problems.
For each n-argument conjunction, my proof producing program
just added a new inductively defined n-ary and, plus a few
useful lemmas. The nice thing about Coq here is that split
will work right away on these new conjunctions.
This is an intuitively appealing idea, with a clear story for why it would produce asymptotically significant time and space improvements. However, it doesn't seem natural to use in my case. I essentially have an extensible recursive function, with a case added for any programming language syntax feature the programmer implements. Each case naturally only has at most a 4-way conjunction (and that's in just one case, with no other above a 3-way conjunction). It's only application to large programs that produces many-way conjunctions with medium-sized individual conjuncts.
So, I think it would require some extra work to take advantage of larger "block size." Are you suggesting that I do something like build a flat list of facts and use a Gallina function to block it into the special conjunction type?
I'll also note that even just a single [split] takes multiple seconds in my example. It would be nice for the overall split to be instantaneous, and your suggestion doesn't seem to lead in that direction.
Thanks to everyone for the help!
