coq-club - Re: [Coq-Club] Proving large conjunctions?
  • From: Frédéric Besson <frederic.besson AT inria.fr>
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Proving large conjunctions?
  • Date: Thu, 19 Jul 2012 15:59:10 +0200
Hi,
I tried to tackle your problem using proof by reflection.
This seems to be significantly faster:
the equivalent of repeat split takes 180s for (truuue 40) ~ 40000 sub-goals
but bigger problems trigger a stack overflow.
Inductive Tree : Type :=
| Leaf (A:Prop)
| Node (L:Tree) (R:Tree).
Fixpoint iTree (t : Tree) : Prop :=
match t with
| Leaf A => A
| Node L R => (iTree L) /\ (iTree R)
end.
Fixpoint xflatten (t : Tree) (acc: Prop) : Prop :=
match t with
| Leaf A => A -> acc
| Node L R => xflatten L (xflatten R acc)
end.
Lemma xflatten_split : forall t (p:Prop), (iTree t -> p) -> xflatten t p.
Proof.
induction t.
simpl. tauto.
simpl.
intros.
apply IHt1.
intros.
apply IHt2.
intros.
apply H ; tauto.
Qed.
Lemma flatten_split : forall t, xflatten t (iTree t).
Proof.
intros.
apply xflatten_split ; auto.
Qed.
Fixpoint truueT (n : nat) : Tree :=
match n with
| O => Leaf True
| S n' => Node (Leaf True) (truueT n')
end.
Fixpoint truuueT (n : nat) : Tree :=
match n with
| O => Leaf True
| S n' => Node (truueT 1000) (truuueT n')
end.
Set Silent.
Goal iTree (truuueT 40).
Time generalize (flatten_split (truuueT 40));
set (f := truuueT 40);
generalize (iTree f);
intros ; compute in H; apply H; clear H.
