- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] refine skipping hole
- Date: Sat, 6 Oct 2012 21:27:11 +0200
Le Sat, 06 Oct 2012 11:17:09 -0700,
S3
<scubed2 AT gmail.com>
a écrit :
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> To learn about accessibility and well-foundedness,
> I tried to prove that the Ackermann function is well-founded.
> I'm using "Coq 8.3pl1 (July 2011)". (Yes, I know that I can
> just write it using 2 fixes.)
> I wrote the program at the bottom of this message.
> However, when I go to prove the ack_step function
> (in the comment at the bottom), I leave 2 holes.
> However, refine only adds the 2nd as an obligation,
> skipping the first. How do I manually add an
> Existential as an Obligation?
> I tried many variations of
> Focus Existential 1.
> Focus ?45.
> etc.
> but none of them allow me to go to it.
> Why is it skipped?
> How do I Focus on it?
> Ackermann function.
> Attempt showing well-foundedness with the Ackermann function,
> even though nest recursion handles it directly.
> I am having a problem with refine skipping a hole.
> How do I go to the hole explicitly?
> Definition ack_ord (p q : nat*nat) :=
> let (a1, b1) := p in
> let (a2, b2) := q in
> a1 < a2 \/ (a1 = a2 /\ b1 < b2)
> Theorem le_Sn_0 n: S n <= 0 -> False.
> intros.
> inversion H.
> Qed.
> Theorem le_S_both a b: a <= b -> S a <= S b.
> intros.
> induction H.
> apply le_n.
> apply le_S.
> apply IHle.
> Qed.
> Theorem le_0 a: 0 <= a.
> induction a.
> apply le_n.
> apply le_S.
> apply IHa.
> Qed.
> Theorem ack_wf_b: forall a, Acc ack_ord (a, 0) -> forall b, Acc
> ack_ord (a, b). intros.
> induction b.
> apply H.
> apply Acc_intro.
> induction y.
> intros.
> induction H0.
> apply (Acc_inv IHb).
> apply or_introl.
> apply H0.
> induction H0.
> rewrite H0.
> clear H0 a0.
> inversion H1.
> apply IHb.
> apply IHb.
> apply or_intror.
> apply conj.
> apply eq_refl.
> apply H2.
> Qed.
> Theorem ack_wf: well_founded ack_ord.
> unfold well_founded.
> induction a.
> apply ack_wf_b.
> clear b.
> induction a.
> apply Acc_intro.
> induction y.
> intros.
> induction H.
> apply le_Sn_0 in H.
> apply (False_ind _ H).
> induction H.
> apply le_Sn_0 in H0.
> apply (False_ind _ H0).
> apply Acc_intro.
> induction y.
> intros.
> apply ack_wf_b.
> induction H.
> inversion H.
> apply IHa.
> apply (Acc_inv IHa).
> apply or_introl.
> apply H1.
> induction H.
> Qed.
> Theorem ack_step x (f : forall y, ack_ord y x -> nat) : nat.
> refine (
> match x as z return x = z -> nat with
> | pair a b => fun H =>
> match a as c return a = c -> nat with
> | 0 => fun _ => S b
> | S a0 => fun H2 =>
> f (
> a0,
> match b as d return b = d -> nat with
> | 0 => fun _ => 1
> | S b0 => fun H3 => f (a, b0) _
> end (eq_refl b)
> ) _
> end (eq_refl a)
> end (eq_refl x)
> (* Skips first hole for f (a, b0) _ *)
> (* 2nd hole *)
> rewrite H.
> rewrite H2.
> apply or_introl.
> apply le_n.
> (* Can't save, how do I go back to first Existential hole? *)
> No more subgoals but non-instantiated existential variables:
> Existential 1 =
> ?56 : [x : nat * nat
> f : forall y : nat * nat, ack_ord y x -> nat
> a : nat
> b : nat
> a0 := a : nat
> b0 := b : nat
> H : x = (a, b)
> a1 : nat
> a2 := a1 : nat
> H2 : a0 = S a1
> b1 : nat
> b2 := b1 : nat
> H3 : b0 = S b1 |- ack_ord (a0, b2) x]
> $_="sccc,gB1,a_oo,JosBackuSa,g11,ug1a,oscc,cBBg,JcgaBuucaB_s11_Juc_c";
> while(($c,$b,$a)=m/^(.)([^,]*),(.*)$/){$_=$a;s/$c/$b/g;}
> print map chr length,split /_/;
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v2.0.17 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAlBwdaUACgkQxzVgPqtIcfuU9ACfZK3zfxqINhYXXcpIGPelB/ML
> FYYAnA4G/uNtHc9ihScfvAP1g569iEAW
> =M++a
> -----END PGP SIGNATURE-----
I am not sure if the following solution is an acceptable answer.
In general, you can use the "instantiate" tactic to fill an
existential. But in doing so, you have to provide a full term.
refine (
| 0 => fun _ => S b
| S a0 => fun H2 =>
let g := fun b0 H3 => _ in
f (
a0,
| 0 => fun _ => 1
| S b0 => fun H3 => f (a, b0) (g b0 H3)
end (eq_refl b)
) _
end (eq_refl a)
end (eq_refl x)
subst.
right; repeat constructor.
(* 2nd hole *)
subst.
apply or_introl.
apply le_n.
- [Coq-Club] refine skipping hole, S3, 10/06/2012
- Re: [Coq-Club] refine skipping hole, AUGER Cédric, 10/06/2012
- [Coq-Club] Re: refine skipping hole, S3, 10/07/2012
- Re: [Coq-Club] Re: refine skipping hole, Arnaud Spiwack, 10/08/2012
- Re: [Coq-Club] Re: refine skipping hole, S3, 10/09/2012
- Re: [Coq-Club] Re: refine skipping hole, Arnaud Spiwack, 10/09/2012
- Re: [Coq-Club] Re: refine skipping hole, AUGER Cédric, 10/09/2012
- Re: [Coq-Club] Re: refine skipping hole, Pierre Courtieu, 10/09/2012
- Re: [Coq-Club] Re: refine skipping hole, Enrico Tassi, 10/09/2012
