- From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- To: S3 <scubed2 AT gmail.com>
- Cc: AUGER Cédric <sedrikov AT gmail.com>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Re: refine skipping hole
- Date: Tue, 9 Oct 2012 07:49:08 +0200
By exposes all holes, you mean that all holes are added as goals?
Would it be possible to selectively convert from
Existentials into goals? e.g. say I want have
Existential ?86
It would be convenient if I could just ask for
?86 to be a goal.
I suppose it would be possible, but I haven't implemented it yet. Part of the problem is how to name, on the user side, existential variable: you cannot use the displayed name as it is not stable, that's why the instantiate tactics count them from 1, but it always seemed unsatisfactory to me (in particular, I tended to get the numbering wrong every time). So I implemented a command which was easy to understand. I also plan to implement a converse tactic, which dismisses goals (typically dependent existential variables), but it's not done yet.
- [Coq-Club] refine skipping hole, S3, 10/06/2012
- Re: [Coq-Club] refine skipping hole, AUGER Cédric, 10/06/2012
- [Coq-Club] Re: refine skipping hole, S3, 10/07/2012
- Re: [Coq-Club] Re: refine skipping hole, Arnaud Spiwack, 10/08/2012
- Re: [Coq-Club] Re: refine skipping hole, S3, 10/09/2012
- Re: [Coq-Club] Re: refine skipping hole, Arnaud Spiwack, 10/09/2012
- Re: [Coq-Club] Re: refine skipping hole, AUGER Cédric, 10/09/2012
- Re: [Coq-Club] Re: refine skipping hole, Pierre Courtieu, 10/09/2012
- Re: [Coq-Club] Re: refine skipping hole, Enrico Tassi, 10/09/2012
