coq-club - [Coq-Club] Excluded middle and decidable equality
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Excluded middle and decidable equality
  • Date: Thu, 26 Sep 2013 18:48:49 +0530
  • Cancel-lock: sha1:oKCdF5cUgV5rN1Q7pxOupfW6wzw=
This question arose out of the exercises on classical logic and the
pigeonhole principle in Pierce's software foundations book:
http://www.cis.upenn.edu/~bcpierce/sf/Logic.html
Consider the following propositions:
Definition excluded_middle : Prop :=
forall P : Prop, P \/ ~ P.
Definition exmid_eq (X : Type) : Prop :=
forall x y : X, x = y \/ x <> y.
I want to prove this:
Theorem A :
(forall X : Type, exmid_eq X) -> excluded_middle.
I want to use a construction which I saw in a paper of Andreas Blass (An
Induction Principle and Pigeonhole Principles for K-Finite Sets,
arXiv:math/9405204 [math.LO], Proof of Theorem 4). I am wondering how
to formalise that argument in Coq.
The construction in Blass's paper starts with a set Y = {u,v} of
cardinality 2. For every proposition P, he defines an equivalence
relation R(P) on Y as follows:
1. (u,u) \in R(P)
2. (v,v) \in R(P)
3. P -> (u,v) \in R(P)
4. P -> (v,u) \in R(P).
Let X(P) = Y / R(P), the quotient set of Y by R(P), and let a(P) and
b(P) be the images of u and v, respectively, in X(P) under the canonical
projection Y -> X(P). By definition,
exmid_eq -> a(P) = b (P) \/ a(P) <> b(P).
Now, a(P) = b(P) -> (u,v) \in R -> P.
Conversely, P -> (u,v) \in R -> a(P) = b(P). Therefore, taking negations,
we get a(P) <> b(P) -> ~ P.
Is my understating of the above construction correct? If so, any hints
on how to define X(P) as a type in Coq?
Best regards,
Raghu.
N. Raghavendra
<raghu AT hri.res.in>,
http://www.retrotexts.net/
Harish-Chandra Research Institute, http://www.hri.res.in/
