coq-club - Re: [Coq-Club] Propositional extensionality is inconsistent in Coq
  • From: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Propositional extensionality is inconsistent in Coq
  • Date: Fri, 13 Dec 2013 10:05:07 +0100
Hi,
How wrong am I if I say that the problem is not the termination checker,
it is this weird thing that is Prop.
I mean : No one would pretend that
(fun (x : Empty) => match x with end) = (fun (x : Empty) => x)
does she ?
So yes maybe, the termination checker has to be obfuscated by Prop as
case analysis typing rule is. Anyway, I would like a way to say that
impossible branches are subterms in a proof relevant setting and I still
don't see a reason to forbid myself to have one. Am I still half
asleep ?
Pierre B.
Le vendredi 13 décembre 2013 à 08:21 +0100, Christine Paulin a écrit :
> On 12/13/2013 02:01 AM, Daniel Schepler wrote:
> > I'd have to agree: the problem here would seem to be that it's
> > highly suspect for
> > match Heq ... with | eq_refl => fun f => match f with end end
> > to be considered a subterm of any u:True.
> I agree with that, it looks like a serious bug in the guard condition
> The principle is the recursive call in the definition of f x should be
> of the form
> f t
> with t a strict recursive subterm of x
> there is a rule to accept a term t of the form (match u with t1 .. tn
> end)
> whenever all ti are recursive subterms of x
> in particular when u has type False (match u with end) is
> accepted
> the justification for this rule is that (f (match u with t1 .. tn
> end)) behaves like (match u with (f t1) .. (f tn) end) which is
> correct
> However in that case we end up with something of the form (f (fun x
> => match x with end)) that will definitely not commute.
> So some check needs to be added. A simple idea would be that a
> recursive subterm could never be an abstraction, or to add some finer
> analysis in which context u should be typable.
> Christine
> > (In fact, it was my unease over my hlength example from yesterday
> > being accepted with the second version of hcons_fin_inv, that led me
> > to experiment with it until I morphed it into the example from this
> > morning.)
> > Daniel Schepler
> > On Thu, Dec 12, 2013 at 4:08 PM, Abhishek Anand
> > <abhishek.anand.iitg AT gmail.com>
> > wrote:
> > It seems that Propositional Extensionality is implied by the
> > proof-irrelevant semantics(of Prop) given in
> > http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.55.1709&rep=rep1&type=pdf
> > I quote:
> > " Propositions are interpreted either by the empty
> > set or by a canonical sin-
> > gleton, depending upon their validity in the model.
> > As a consequence all
> > proof-terms are identified. In the same way, tile
> > interpretation of Prop is
> > {0,1}. "
> > So, all true propositions have the same
> > denotation(interpretation). I would guess this means
> > Propositional Extensionality is indeed consistent with Coq's
> > theory.
> > I hope it is just a fixable bug in the
> > implementation(termination analysis?) of Coq.
> > -- Abhishek
> > http://www.cs.cornell.edu/~aa755/
> > On Thu, Dec 12, 2013 at 6:45 PM, Guillaume Melquiond
> > <guillaume.melquiond AT inria.fr>
> > wrote:
> > On 13/12/2013 00:30, Daniel Schepler wrote:
> > The Extensionality_Ensembles axiom in
> > http://coq.inria.fr/distrib/current/stdlib/Coq.Sets.Ensembles.html
> > easily implies propositional extensionality
> > In a similar way, propositional extensionality was
> > used to prove the consistency of the set theory of
> > Why3. And my email would be incomplete if I didn't
> > quote the comment accompanying that Coq proof: "it
> > is folklore that the two together are consistent".
> > Famous last words...
> > Best regards,
> > Guillaume
