- To: Christine Paulin <christine.paulin AT lri.fr>, Viktor Vafeiadis <viktor AT mpi-sws.org>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Propositional extensionality is inconsistent in Coq
- Date: Fri, 13 Dec 2013 17:10:24 +0100
Maybe the time is ripe to switch to a more semantical notion of termination and guardedness. The syntactic guard condition gets you somewhere, but then needs a lot of extensions and patching to work satisfactory in practice. Formal verification of it becomes too difficult, and only intuitive justification is prone to errors.
Let's rather invest our energy in integration type-based termination into our tools, as, e.g., done in this project:
Coq^
http://qatar.cmu.edu/~sacchini/coq.html
This might be a huge initial investment, but I believe it will pay off in the long run.
Andreas
On 13.12.2013 12:05, Christine Paulin wrote:
There are indeed examples where this is needed
for instance to have (pred n) < n when (n<>0) or any other destructor
function
in particular the definition of the fixpoint combinator on well-founded
relations relies on that.
However there is a simple restriction to the match rule that should
solve the problem :
checking the order is done with respect to an inductive definition
Ind (the type of the recusive variable in the fixpoint)
the return type of the match (the one gouverning the type of eache
branch) should produce something in this inductive definition (so be of
the form (x1:A1)...(xn:An)Ind)
This added condiction should be enough to establish an invariant that
will guarantee the safety of the condition.
when doing an elimination on the proof of X=Y to change an object
of type X into an object of type Y the predicate is fun (p:Prop => p)
which does not meet the condition. Other useful match constructions that
I know should pass the test.
Christine
On 12/13/2013 11:04 AM, Viktor Vafeiadis wrote:
On 13 Dec 2013, at 08:21, Christine Paulin wrote:
The principle is the recursive call in the definition of f x should[...]
be of the form
f t
with t a strict recursive subterm of x
there is a rule to accept a term t of the form (match u with t1 .. tn
end)
whenever all ti are recursive subterms of x
in particular when u has type False (match u with end) is accepted
So some check needs to be added. A simple idea would be that aAn even simpler fix would be to just drop the rule that accepts (match
recursive subterm could never be an abstraction, or to add some finer
analysis in which context u should be typable.
u with t1 .. tn end) as a subterm.
I wonder whether there are any actual proofs that rely on recursive
definitions of such form.
Viktor
Andreas Abel <>< Du bist der geliebte Mensch.
Theoretical Computer Science, University of Munich
Oettingenstr. 67, D-80538 Munich, GERMANY
andreas.abel AT ifi.lmu.de
http://www2.tcs.ifi.lmu.de/~abel/
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, (continued)
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Daniel Schepler, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Christine Paulin, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Pierre Boutillier, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Maxime Dénès, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Arnaud Spiwack, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Viktor Vafeiadis, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Andreas Abel, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Anthony Bordg, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Guillaume Brunerie, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Matthieu Sozeau, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Jacques-Henri Jourdan, 12/13/2013
