coq-club - Re: [Coq-Club] Propositional extensionality is inconsistent in Coq
  • From: Christine Paulin <christine.paulin AT lri.fr>
  • To: Viktor Vafeiadis <viktor AT mpi-sws.org>, coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Propositional extensionality is inconsistent in Coq
  • Date: Fri, 13 Dec 2013 12:05:53 +0100
  • Organization: Université Paris-Sud
There are indeed examples where this is needed
for instance to have (pred n) < n when (n<>0) or any other destructor function
in particular the definition of the fixpoint combinator on well-founded relations relies on that.
However there is a simple restriction to the match rule that should solve the problem :
checking the order is done with respect to an inductive definition Ind (the type of the recusive variable in the fixpoint)
the return type of the match (the one gouverning the type of eache branch) should produce something in this inductive definition (so be of the form (x1:A1)...(xn:An)Ind)
This added condiction should be enough to establish an invariant that will guarantee the safety of the condition.
when doing an elimination on the proof of X=Y to change an object of type X into an object of type Y the predicate is fun (p:Prop => p) which does not meet the condition. Other useful match constructions that I know should pass the test.
Christine
On 12/13/2013 11:04 AM, Viktor Vafeiadis wrote:
On 13 Dec 2013, at 08:21, Christine Paulin wrote:
The principle is the recursive call in the definition of f x should be of the
form
f t
with t a strict recursive subterm of x
there is a rule to accept a term t of the form (match u with t1 .. tn end)
whenever all ti are recursive subterms of x
in particular when u has type False (match u with end) is accepted
So some check needs to be added. A simple idea would be that a recursive
subterm could never be an abstraction, or to add some finer analysis in which
context u should be typable.
An even simpler fix would be to just drop the rule that accepts (match u with
t1 .. tn end) as a subterm.
I wonder whether there are any actual proofs that rely on recursive
definitions of such form.
Viktor
