- From: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Propositional extensionality is inconsistent in Coq
- Date: Fri, 13 Dec 2013 10:49:50 +0100
My point was : Empty_set -> Empty_set = unit is a crazy thing, doesn't
it ?
So are universal subterms an issue in Type ?
But as Arnaud said, I need to wake up before thinking further :-)
Le vendredi 13 décembre 2013 à 04:20 -0500, Maxime Dénès a écrit :
> Hi Pierre,
> I am not sure to see what you mean. The term (fun (x : Empty) => match x
> with end) will still be considered by the current termination checker as
> a subterm of any recursive argument, am I wrong? So the issue does not
> seem specific to Prop.
- [Coq-Club] Propositional extensionality is inconsistent in Coq, Maxime Dénès, 12/12/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Pierre-Marie Pédrot, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Daniel Schepler, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Guillaume Melquiond, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Abhishek Anand, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Christine Paulin, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Pierre Boutillier, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Maxime Dénès, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Arnaud Spiwack, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Viktor Vafeiadis, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Andreas Abel, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Anthony Bordg, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Guillaume Brunerie, 12/13/2013
