- To: Christine Paulin <christine.paulin AT lri.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Propositional extensionality is inconsistent in Coq
- Date: Fri, 13 Dec 2013 11:04:09 +0100
On 13 Dec 2013, at 08:21, Christine Paulin wrote:
> The principle is the recursive call in the definition of f x should be of
> the form
> f t
> with t a strict recursive subterm of x
> there is a rule to accept a term t of the form (match u with t1 .. tn end)
> whenever all ti are recursive subterms of x
> in particular when u has type False (match u with end) is accepted
> So some check needs to be added. A simple idea would be that a recursive
> subterm could never be an abstraction, or to add some finer analysis in
> which context u should be typable.
An even simpler fix would be to just drop the rule that accepts (match u with
t1 .. tn end) as a subterm.
I wonder whether there are any actual proofs that rely on recursive
definitions of such form.
Viktor
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, (continued)
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Daniel Schepler, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Guillaume Melquiond, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Abhishek Anand, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Christine Paulin, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Pierre Boutillier, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Maxime Dénès, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Arnaud Spiwack, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Viktor Vafeiadis, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Andreas Abel, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Anthony Bordg, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Guillaume Brunerie, 12/13/2013
