coq-club - Re: [Coq-Club] Propositional extensionality is inconsistent in Coq
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Propositional extensionality is inconsistent in Coq
  • Date: Tue, 17 Dec 2013 23:32:35 +0100
Several people have commented on the univalence and the present
trouble. I would just like to clarify the situation a bit more.
It is indeed the case that univalence implies that (False -> False) =
True. However:
1) in HoTT we do not use Prop, so that should really be (Empty_set ->
Empty_set) = unit.
2) In HoTT we do not use match statements but rather the eliminators.
I do not see how to reproduce the problem using False_rect.
3) There are numerous other incompatibilities between Coq and HoTT,
which is why HoTT uses a patched Coq and abstains from using certain
parts of Coq.
On a more personal note, I think the present situation shows the value
of having some semantics around to curb hasty adoption of rules that
"look OK".
With kind regards,
Andrej
