- From: Cristóbal Camarero Coterillo <nakacristo AT hotmail.com>
- To: Christine Paulin <christine.paulin AT lri.fr>
- Cc: "jacques-henri.jourdan AT inria.fr" <jacques-henri.jourdan AT inria.fr>, "mail AT maximedenes.fr" <mail AT maximedenes.fr>, "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] Propositional extensionality is inconsistent in Coq
- Date: Tue, 17 Dec 2013 17:06:53 +0000
- Importance: Normal
The hypothesis "forall y:False, f y < x" certainly does not give any information and we cannot prove "(match Heq in (False->True2=True2) return fun X _ => X with eq_refl => f end) < x" .
But returning to the example of the mutually inductive type we can do the following (by adding proof-irrelevance):
Inductive True1 : Prop := I1 : True1
with True2 : Prop := I2 : True1 -> True2.
Section func_unit_discr.
Hypothesis Heq : True1 = True2.
Fixpoint contradiction (u : True2) : False :=
contradiction (
match u with
| I2 Tr =>
match Heq in (_ = T) return T with
| eq_refl => Tr
end
end).
(*proof-irrelevance for eq*)
Axiom destruct_eq: forall {T:Type} {x:T} (H:x=x), H=eq_refl.
Theorem structural: forall (lower: forall {T:Type}, T->True2->Prop) (x:True2),
match x with
I2 Tr => (lower Tr x)
-> lower (match Heq with eq_refl => Tr end) x
end.
Proof.
intros. destruct x.
set(Heq':=Heq). clearbody Heq'.
set(I2':=I2). clearbody I2'.
revert t Heq' I2'. rewrite Heq.
intros. rewrite (destruct_eq Heq').
exact H.
Qed.
End func_unit_discr.
I think the theorem "structural" is what is required for the fixpoint to work.
Although Heq cannot be immediately eliminated we can work around it.
contradiction (
match u with
| I2 Tr =>
| eq_refl => Tr
end
end).
match x with
end.
Proof.
intros. destruct x.
exact H.
Qed.
> Date: Mon, 16 Dec 2013 20:35:08 +0100
> From: Christine.Paulin AT lri.fr
> To: nakacristo AT hotmail.com
> CC: jacques-henri.jourdan AT inria.fr; mail AT maximedenes.fr; coq-club AT inria.fr
> Subject: Re: [Coq-Club] Propositional extensionality is inconsistent in Coq
> > Following the arguments of my previous email, if we rewrite
> > (False->True2)=True2 in the inductive definition we would get
> > Inductive True2:Prop:= I2: True2->True2.
> > which is False when the original is True.
> Very nice example but we should not misinterpret this last point
> in order to identify
> with
> Inductive True2:Prop:= I2: (False -> True2)->True2.
> you need (False -> X) = X forall X (which is not provable when X is
> False) and not just False -> True2 = True2
> because the name is bound in the inductive definition
> so the problem is still the same around the elimination on Heq "
> assume < is the structural order related to True2 generated by (forall
> y, f y < l2 f)
> Fixpoint con (x:True2) :False :=
> match x with
> I2 f => con (match Heq with eq_refl => f end)
> end.
> The hypothesis
> forall y, f y < x
> we would like to prove
> end) < x
> but eliminating Heq requires a generalisation
> (match Heq in (False->True2=Z) return fun X _ => X with eq_refl => f
> end) < x
> which is not well-typed.
> This is this situation we need to detect and forbid.
> The point being not to miss tricky situations
> Christine
> with
> y, f y < l2 f)
> match x with
> end.
> The hypothesis
> forall y, f y < x
> end) < x
> end) < x
> Christine
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, (continued)
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Jacques-Henri Jourdan, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Jacques-Henri Jourdan, 12/14/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, AUGER Cédric, 12/14/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Maxime Dénès, 12/14/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Christine Paulin, 12/15/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Arthur Azevedo de Amorim, 12/20/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Christine Paulin, 12/20/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Cristóbal Camarero Coterillo, 12/16/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Christine Paulin, 12/16/2013
- RE: [Coq-Club] Propositional extensionality is inconsistent in Coq, Cristóbal Camarero Coterillo, 12/17/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Christine Paulin, 12/17/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Andrej Bauer, 12/17/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Bruno Barras, 12/18/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Vladimir Voevodsky, 12/18/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Maxime Dénès, 12/18/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Ali Assaf, 12/19/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Bruno Barras, 12/19/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Vladimir Voevodsky, 12/19/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, croux, 12/19/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Ali Assaf, 12/20/2013
