- To: Jacques-Henri Jourdan <jacques-henri.jourdan AT inria.fr>
- Cc: Maxime Dénès <mail AT maximedenes.fr>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Propositional extensionality is inconsistent in Coq
- Date: Sat, 14 Dec 2013 21:56:45 +0100
Le Sat, 14 Dec 2013 19:36:58 +0100 (CET),
a écrit :
> Note that we can build a similar contradiction without using a
> pattern matching with no branches :
> Require Import ClassicalFacts.
> Inductive True1 : Prop := I1 : True1
> with True2 : Prop := I2 : True1 -> True2.
> Section func_unit_discr.
> Hypothesis Heq : True1 = True2.
> Fixpoint contradiction (u : True2) : False :=
> contradiction (
> match u with
> | I2 Tr =>
> match Heq in (_ = T) return T with
> | eq_refl => Tr
> end
> end).
> End func_unit_discr.
> Lemma foo : provable_prop_extensionality -> False.
> Proof.
> intro; apply contradiction.
> etransitivity. apply H. constructor.
> symmetry. apply H. constructor. constructor.
> Qed.
> I am not sure I have understood the tentative fix of Christine
> Paulin, but it seems like this would not solve this case either
> (True1 and True2 are in the same inductive definition.
I think there should clearly be a bug here.
When I first saw:
I immediately thought "hey, this should not be marked as mutually
inductive, True simply depends on True1, but True1 does not depend on
True2".
So I removed the "with" and replaced it with a ". Inductive", but there
"contradiction" became rejected while original form is accepted. From my
point of view, such a diverging behavior should never occur.
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, (continued)
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Robbert Krebbers, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Maxime Dénès, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Anthony Bordg, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Guillaume Brunerie, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Arnaud Spiwack, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Jacques-Henri Jourdan, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Matthieu Sozeau, 12/13/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Jacques-Henri Jourdan, 12/14/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, AUGER Cédric, 12/14/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Maxime Dénès, 12/14/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Christine Paulin, 12/15/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Arthur Azevedo de Amorim, 12/20/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Christine Paulin, 12/20/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Cristóbal Camarero Coterillo, 12/16/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Christine Paulin, 12/16/2013
- RE: [Coq-Club] Propositional extensionality is inconsistent in Coq, Cristóbal Camarero Coterillo, 12/17/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Christine Paulin, 12/17/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Andrej Bauer, 12/17/2013
