- From: Christine Paulin <christine.paulin AT lri.fr>
- To: Cristóbal Camarero Coterillo <nakacristo AT hotmail.com>
- Cc: "jacques-henri.jourdan AT inria.fr" <jacques-henri.jourdan AT inria.fr>, "mail AT maximedenes.fr" <mail AT maximedenes.fr>, coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Propositional extensionality is inconsistent in Coq
- Date: Tue, 17 Dec 2013 18:33:05 +0100
- Organization: Université Paris-Sud
Yes it is true that if you can build a generic relation lower: forall {T:Type}, T->True2->Prop such that (lower Tr (l2 Tr)) then you can prove your match term is smaller but could you prove it is well-founded ? I doubt it (because of the parametricity) my point was to stay with the relation associated to the inductive definitions comparing objects in True1 and True2 only Christine On 12/17/2013 06:06 PM, Cristóbal
Camarero Coterillo wrote:
The hypothesis "forall y:False, f y < x"
certainly does not give any information and we cannot prove
"(match Heq in (False->True2=True2) return fun X _ => X
with eq_refl => f end) < x" .
But returning to the example of the mutually inductive type we can do the following (by adding proof-irrelevance): Inductive True1 : Prop := I1 : True1 with True2 : Prop := I2 : True1 -> True2. Section func_unit_discr. Hypothesis Heq : True1 = True2. Fixpoint contradiction (u : True2) : False := contradiction ( match u with | I2 Tr => match Heq in (_ = T) return T with | eq_refl => Tr end end). (*proof-irrelevance for eq*) Axiom destruct_eq: forall {T:Type} {x:T} (H:x=x), H=eq_refl. Theorem structural: forall (lower: forall {T:Type}, T->True2->Prop) (x:True2), match x with I2 Tr => (lower Tr x) -> lower (match Heq with eq_refl => Tr end) x end. Proof. intros. destruct x. set(Heq':=Heq). clearbody Heq'. set(I2':=I2). clearbody I2'. revert t Heq' I2'. rewrite Heq. intros. rewrite (destruct_eq Heq'). exact H. Qed. End func_unit_discr. I think the theorem "structural" is what is required for the fixpoint to work. Although Heq cannot be immediately eliminated we can work around it. > Date: Mon, 16 Dec 2013 20:35:08 +0100
> From: Christine.Paulin AT lri.fr > To: nakacristo AT hotmail.com > CC: jacques-henri.jourdan AT inria.fr; mail AT maximedenes.fr; coq-club AT inria.fr > Subject: Re: [Coq-Club] Propositional extensionality is inconsistent in Coq > > > > > > Following the arguments of my previous email, if we rewrite > > (False->True2)=True2 in the inductive definition we would get > > Inductive True2:Prop:= I2: True2->True2. > > which is False when the original is True. > Very nice example but we should not misinterpret this last point > in order to identify > > Inductive True2:Prop:= I2: True2->True2. > with > Inductive True2:Prop:= I2: (False -> True2)->True2. > > you need (False -> X) = X forall X (which is not provable when X is > False) and not just False -> True2 = True2 > because the name is bound in the inductive definition > > so the problem is still the same around the elimination on Heq " > > assume < is the structural order related to True2 generated by (forall > y, f y < l2 f) > > Fixpoint con (x:True2) :False := > match x with > I2 f => con (match Heq with eq_refl => f end) > end. > > The hypothesis > forall y, f y < x > we would like to prove > > (match Heq in (False->True2=True2) return fun X _ => X with eq_refl => f > end) < x > > but eliminating Heq requires a generalisation > > (match Heq in (False->True2=Z) return fun X _ => X with eq_refl => f > end) < x > > which is not well-typed. > > This is this situation we need to detect and forbid. > The point being not to miss tricky situations > > Christine > > > > > |
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, (continued)
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Jacques-Henri Jourdan, 12/14/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, AUGER Cédric, 12/14/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Maxime Dénès, 12/14/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Christine Paulin, 12/15/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Arthur Azevedo de Amorim, 12/20/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Christine Paulin, 12/20/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Cristóbal Camarero Coterillo, 12/16/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Christine Paulin, 12/16/2013
- RE: [Coq-Club] Propositional extensionality is inconsistent in Coq, Cristóbal Camarero Coterillo, 12/17/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Christine Paulin, 12/17/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Andrej Bauer, 12/17/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Bruno Barras, 12/18/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Vladimir Voevodsky, 12/18/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Maxime Dénès, 12/18/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Ali Assaf, 12/19/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Bruno Barras, 12/19/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Vladimir Voevodsky, 12/19/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, croux, 12/19/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Ali Assaf, 12/20/2013
- Re: [Coq-Club] Propositional extensionality is inconsistent in Coq, Ramana Kumar, 12/20/2013
