Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
- To: Vladimir Voevodsky <vladimir AT ias.edu>, Cody Roux <cody.roux AT andrew.cmu.edu>
- Cc: coq-club Club <coq-club AT inria.fr>, "agda AT lists.chalmers.se" <agda AT lists.chalmers.se>, "homotopytypetheory AT googlegroups.com" <homotopytypetheory AT googlegroups.com>
- Subject: Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
- Date: Wed, 08 Jan 2014 22:45:12 +0100
On 08/01/2014 20:55, Vladimir Voevodsky wrote:
> On Jan 8, 2014, at 12:40 PM, Cody Roux
> wrote:
>> That's fair, but I don't see why eliminators have a more powerful
>> ontological status than sized-types. They require work to be derived as
>> well, and the correctness proofs for them are quite similar to that for
>> sized types. This seems like a matter of preference. Obviously I'm not
>> neutral in this matter though.
>> Best,
>> Cody
> In the case of the univalent model eliminators are better because I have
> invested a lot of effort into checking that they are compatible with the
> model (some details of it are at the end of my "Notes on Type Systems").
As Cody said, it is likely that a lot of this work can be reused (or at
least adapted) if you switch to sized-types. The only new ingredient is
ordinal iteration, and the fact that those ordinals are not used in the
process you iterate. This is what I call "stage irrelevance" in my
habilitation thesis. Andreas has something similar in his
implementation. IIUC it's an implicit product, which is much more
flexible than stage irrelevance, but harder to understand set-theoretically.
I must admit that the situation is quite different with higher inductive
types. The eliminator does not split into pattern-matching + fixpoint in
the obvious way. That's the main blocking issue I'm facing in my
implementation of HITs. (I've tried to explain this in Barcelona last
September.) However, I'm not going to surrender so easily.
Bruno.
- Re: [Coq-Club] [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, (continued)
- Re: [Coq-Club] [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Frédéric Blanqui, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Altenkirch Thorsten, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Matthieu Sozeau, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Conor McBride, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Bruno Barras, 01/09/2014
- RE: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Nikhil Swamy, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Cody Roux, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Frédéric Blanqui, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Jean Goubault-Larrecq, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Vladimir Voevodsky, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Bruno Barras, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Andrej Bauer, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Andrej Bauer, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Vladimir Voevodsky, 01/09/2014
