Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
- To: Matthieu Sozeau <matthieu.sozeau AT gmail.com>, Frédéric Blanqui <frederic.blanqui AT inria.fr>
- Cc: Coq Club <coq-club AT inria.fr>, "agda AT lists.chalmers.se list" <agda AT lists.chalmers.se>, HomotopyTypeTheory AT googlegroups.com
- Subject: Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
- Date: Thu, 09 Jan 2014 12:16:48 +0100
On 09/01/2014 11:40, Matthieu Sozeau wrote:
Hi,
I can’t speak for Andrej, but my point was not to disqualify sized-types,
they are a fine, evidence-based foundation, just like wellfounded relations,
to define recursive definitions. The nice thing about wellfounded relations
is that they are readily available, supposing we have at least eliminators.
I’m curious about the respective expressive power of both, my gut feeling is
that w.f. relations are most general but this is not backed up by anything
formal. My question about sized types is how do you justify definitions
on big ordinals defined *in* the type theory using the metatheoretical
ordinals.
It might reduce to Bruno’s [… and the fact that those ordinals are not used
in the
process you iterate…] and be a solved question. Then Andrej might be worried
that
the metatheory has to be classical if you use ordinals (?) (but for wfs it
wouldn’t
be??).
The metatheory does not need to be classical. When I talked about ordinals, I meant "something you can use to iterate long enough". No need for the well-ordering property to justify inductive definitions, for both the sized-types or the recursor-based approaches (the former implies the latter).
I use Paul Taylor's directed plump ordinals, and you can go a long way with them. The strictly positive inductive types of Coq (those in Type) can be modeled (to prove consistency and SN) in IZF with replacement. If you include those in Prop, then I did manage to go through using the collection axiom, but still without excluded-middle. (BTW, I'm talking of machine checked proofs.)
Bruno.
- RE: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, (continued)
- RE: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Nikhil Swamy, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Cody Roux, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Frédéric Blanqui, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Jean Goubault-Larrecq, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Vladimir Voevodsky, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Bruno Barras, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Andrej Bauer, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Matthieu Sozeau, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Bruno Barras, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Andrej Bauer, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Vladimir Voevodsky, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Andreas Abel, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Altenkirch Thorsten, 01/09/2014
