coq-club - Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
  • From: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
  • To: Vladimir Voevodsky <vladimir AT ias.edu>
  • Cc: Andrej Bauer <andrej.bauer AT andrej.com>, Coq Club <coq-club AT inria.fr>, "agda AT lists.chalmers.se" <agda AT lists.chalmers.se>, Cody Roux <cody.roux AT andrew.cmu.edu>, "homotopytypetheory AT googlegroups.com" <homotopytypetheory AT googlegroups.com>
  • Subject: Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
  • Date: Thu, 9 Jan 2014 00:39:38 +0100
On 9 janv. 2014, at 00:31, Vladimir Voevodsky
wrote:
> On Jan 8, 2014, at 5:19 PM, Andrej Bauer
> wrote:
>> It would
>> seem sensible to me to go the same route with inductive definitions,
>> namely, rely on semantic justifications rather than syntactic ones.
> This would certainly be cool. What I do not quite understand however is
> what ordinals or well-founded relations have with such inductive definition
> as, for example, the definition of "less or equal" on nat in the Coq
> standard library?
> (It's something like:
> Inductive le : forall ( n m : nat ) , Type := le_refl : forall ( n : nat )
> , le n n | le_succ : forall ( n m : nat ) , le n m -> le (S n ) ( S m ) .
Well, take the transitive closure of p <_le le_succ n m p.
— Matthieu
