coq-club - Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
  • Date: Thu, 09 Jan 2014 12:19:53 -0500
On 01/09/2014 10:42 AM, Andrej Bauer wrote:
Sorry but I don't really understand Andrej and Mathieu's last mails. In
size-based termination, there is no ordinal in the type system itself.
Ordinals are just used in the meta-theory to justify that, indeed, every
well typed term terminates.
I was just pointing out that well-founded relations are the correct
notion to use.
Ordinals require classical logic so you'll burn when you try to bring
measures of termination from meta-theory down to theory. For instance,
what happens if you want to formalize the meta-theory? You can only
sensibly formalize ordinals if you have excluded middle, otherwise
they get weird.
They get weird, but they suffice for our purposes. As Bruno pointed out, ordinals can be formalized just fine in IZF, but they have the bizarre property of being neither linear, nor have the "successor/limit" property: in general it is not true that an ordinal is either a successor or a limit.
Conveniently, neither of these properties is required to carry out the meta-theory of sized-types. Can we carry out the same formalization using measures and well-founded induction? It's likely, but it would be nice to have a single, unified rule for defining recursive functions.
The real question is: what is required for a function definition, and what computation rules result? If we only have recursors, then we can define functions by well-founded recursion, and all is fine, except when we get around to actually having to prove things about recursive functions.
Mathieu pointed out that with sufficiently heavy elaboration on top of this, we can "hide" the difficulties behind nice ad-hoc induction principles and adding enough "steam" to the acc type to be able to unfold open terms. Maybe this is the way to go, but certainly efficiency will be lost at the conversion stage, where huge terms with recursors and proofs of well-foundedness will be floating around.
I guess I'm getting off track here, so I'll just finish with this remark: ordinals are simply a useful -approximation- to the shape of a term, which in turn can be manipulated to give a nice type-based criterion for size decrease in recursive calls. This is all size-based termination is. We all agree that the fact that ordinals are well-ordered (classically) is not fundamental, but nevertheless I don't see any well-studied alternative to measure decrease in recursive calls. Like I tried to say above, having a user define the well-founded order for each recursive function, or more likely having Coq fill in the blanks each time has some drawbacks.
Best,
Cody
Ordinals are well-founded and *linear*, and there will be cases where
the well-founded part is readily available, but the linearity
requirement just gets in the way. Since linearity is not needed to
show termination, why would we insist on it? For instance, if we want
an automated tool for proving termination, why bother with linearity
when all we need is well-foundedness? (Does Agda termination checker
use ordinals?)
So I really do not see an advantage to using ordinals, except perhaps
easy notation. But I am not actually ruling out ordinals, I am just
saying that we should use the more general well-founded relations, so
the ordinal notations are still there for those cases where they are
the best thing to use.
With kind regards,
Andrej
