- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Tricky recursion?
- Date: Mon, 17 Mar 2014 18:10:29 -0700
Is there an easy way to convince Coq to accept the following recursion?
Fixpoint sum_to (i : nat) (f : nat -> nat) : nat :=
match i with
| O => f O
| S i' => f i + (sum_to i' f)
end.
Parameter G : nat -> nat.
Fixpoint problem (t : nat) : nat :=
match t with
| O => G O
| S t' => sum_to t' (fun t_i => G (problem t_i))
end.
It complains, of course, because Coq doesn't realize that t_i will always be invoked on argument structurally smaller than t. Ideally I could just use a tactic like refine and provide a proof of termination by hand, or something, but I am not quite sure what that should look like.
Any help would be greatly appreciated!
Thanks!
-geoff
- [Coq-Club] Tricky recursion?, Geoff Hulette, 03/18/2014
- Re: [Coq-Club] Tricky recursion?, Cedric Auger, 03/18/2014
- Re: [Coq-Club] Tricky recursion?, Pierre Boutillier, 03/18/2014
- Re: [Coq-Club] Tricky recursion?, Hugo Carvalho, 03/26/2014
- Re: [Coq-Club] Tricky recursion?, Guillaume Melquiond, 03/26/2014
- Re: [Coq-Club] Tricky recursion?, Xavier Leroy, 03/26/2014
