- From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Tricky recursion?
- Date: Wed, 26 Mar 2014 14:24:24 +0100
On 26/03/2014 13:56, Hugo Carvalho wrote:
I wanted to demonstrate a strong recursion scheme that didn't go through
the well-founded machinery. The two texts i'm familiar with, and have a
presentation of general recursion (Coq'Art, and CPDT), use it or
something even more complicated. My point is, this shows how powerful
regular "fix" over the naturals can be, instead of requiring you to
recurse on the structure of some predicate. That's what i found
unexpected, and would like to know more about.
I don't know how it behaves regarding performance. I do remember,
however, that computing with well-founded recursion can be tricky,
sometimes needing you to construct "guarded" Acc proofs, or something
like that. Perhaps this approach is better; perhaps nested "fix"es are
even worse in this regard.
I stand by my point: the proof for a strong recursion scheme does not need to go through the well-founded machinery. As I said, your example is nothing more than the simple structural recursion over natural numbers. Here is a Coq script so that my point is clearer:
Definition nat_strong_rect (P : nat -> Type) :
(forall n : nat, (forall m : nat, m < n -> P m) -> P n) ->
forall n, P n.
Proof.
intros Hs n.
cut (forall m, m < S n -> P m).
intros H.
apply H.
apply lt_n_Sn.
induction n as [|n In] ; intros m Hm.
apply Hs.
rewrite (proj1 (NPeano.Nat.lt_1_r _) Hm).
intros k Hk.
elim lt_n_0 with (1 := Hk).
apply gt_S_le in Hm.
destruct (le_lt_eq_dec _ _ Hm) as [H|H].
apply In with (1 := H).
rewrite H.
apply Hs with (1 := In).
Defined.
As you can see, I do not bother creating a well-founded relation here nor am I doing anything fancy. I am simply doing a naive recursion on n. The proof term contains a straightforward "fix" construct (inside nat_rect), so straightforward that it is the only one "induction" knows about.
To summarize, while "fix" is a powerful construct, strong recursion is not a good example of its power.
Best regards,
Guillaume
- [Coq-Club] Tricky recursion?, Geoff Hulette, 03/18/2014
- Re: [Coq-Club] Tricky recursion?, Cedric Auger, 03/18/2014
- Re: [Coq-Club] Tricky recursion?, Pierre Boutillier, 03/18/2014
- Re: [Coq-Club] Tricky recursion?, Hugo Carvalho, 03/26/2014
- Re: [Coq-Club] Tricky recursion?, Guillaume Melquiond, 03/26/2014
- Re: [Coq-Club] Tricky recursion?, Xavier Leroy, 03/26/2014
