coq-club - Re: [Coq-Club] Tricky recursion?
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Tricky recursion?
  • Date: Tue, 18 Mar 2014 10:49:52 +0100
Some idea:
You know that all recursive calls are smaller, thus if you could define a function ρ:ℕ→ℕ→ℕ such that ∀ x, y. x>y ⇒ ρ x y = problem y, then you could get a solution to your problem, by posing "problem x = ρ (S x) x".
∀ y. ρ O y is irrelevant, so it can be set as O.
∀ x. ρ (S x) O is equal to "problem O", thus it can be set as "G O"
∀ x, y. x > y ⇒ ρ (S x) (S y) is equal to "problem (S y)", thus it should be set to "sum_to y (fun t_i => G (problem t_i))". All 't_i's will be smaller or equal to y, thus "problem t_i" can be replaced by "ρ z t_i" for any z>t_i. As all 't_i's will be smaller than or equal to y, and x>y, "problem t_i" can be replaced with "ρ x t_i". There, the call to ρ is guarded if we do a recursion on the first argument.
Thus:
Fixpoint ρ (x : nat) : nat -> nat :=
  match x with
  | O => fun _ => O
  | S x => fun y =>
           match y with
           | O => G O
           | S y => sum_to y (fun t_i => G (ρ x t_i))
           end
  end.
Definition problem (t : nat) : nat := ρ (S t) t.
could do what you wished.
2014-03-18 2:10 GMT+01:00 Geoff Hulette <ghulette AT gmail.com>:
Is there an easy way to convince Coq to accept the following recursion?
Fixpoint sum_to (i : nat) (f : nat -> nat) : nat :=
  match i with
  | O => f O
  | S i' => f i + (sum_to i' f)
  end.
Parameter G : nat -> nat.
Fixpoint problem (t : nat) : nat :=
  match t with
  | O => G O
  | S t' => sum_to t' (fun t_i => G (problem t_i))
  end.
It complains, of course, because Coq doesn't realize that t_i will always be invoked on argument structurally smaller than t. Ideally I could just use a tactic like refine and provide a proof of termination by hand, or something, but I am not quite sure what that should look like.
Any help would be greatly appreciated!
Thanks!
-geoff
.../Sedrikov\...
