coq-club - Re: [Coq-Club] Tricky recursion?
  • From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Tricky recursion?
  • Date: Wed, 26 Mar 2014 08:31:31 +0100
On 26/03/2014 05:22, Hugo Carvalho wrote:
Whoa, hold on. I looked at this, and thought, "Surely it can't work
Coq's fix is primitive recursive, so no way this kind of definition
works without some well-founded trickery!". Sure enough, it does work,
and even more surprisingly, you can prove a strong recursion scheme over
the naturals using the same trick!
There must be something I am missing, as I don't understand how the example shows anything.
Strong recursion is just simple recursion applied to a more general property. So, by explicitly writing "fix" in your proof script, you are just complicating and obfuscating a proof that is trivial.
If the obtained lambda term was executing faster (less reduction steps for some evaluation strategy) with nested "fix"s rather than with a simple structural induction, that would be convincing. But that does not even seem to be true on your example.
Best regards,
Guillaume
