coq-club - Re: [Coq-Club] Tricky recursion?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Tricky recursion?
  • Date: Wed, 26 Mar 2014 15:25:36 +0100
On 2014-03-26 05:22, Hugo Carvalho wrote:
> Whoa, hold on. I looked at this, and thought, "Surely it can't work
> Coq's fix is primitive recursive, so no way this kind of definition
> works without some well-founded trickery!".
As Guillaume hinted, you can derive your induction principle
Definition mult_rect_str (P : nat -> Type)
(f0 : forall n0 : nat, (forall m : nat, m < n0 -> P m) -> P n0) :
forall n:nat, P n.
from the primitive recursor nat_rect:
nat_rect: forall Q : nat -> Type,
Q 0 -> (forall n : nat, Q n -> Q (S n)) -> forall n : nat, Q n
just by taking Q := fun n => forall m, m < n -> P m.
So, no black magic here.
> That is, just how strong can the application of nested fixpoints be
> in Coq?
As a case in point, you can define Ackermann's function with a fix
nested in a fix. So, clearly, you're going beyond primitive
recursion...
- Xavier Leroy
