[Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?
- To: coq club <coq-club AT inria.fr>
- Subject: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?
- Date: Sat, 12 Apr 2014 13:45:00 +0300
Hi all,
In case you're about to answer this question as "read CPDT", I want to
say that I'm already reading it and but I couldn't find anything
relevant yet and I don't want to wait until I finish the entire book
because it will probably take long time. (if you know which particular
page I need to read, I can of course jump to that page :-) )
Anyway, I'm trying to implement some certified algorithms/data
structures and I came across this problem several times: I can't tell
Coq that tail of discriminee(the value that we're pattern matching on)
is one shorter than the discriminee. An example function:
Fixpoint pt_aux (h : nat) len (v : Vector.t nat (S len)) : Vector.t
nat (S len) :=
match v with
| Vector.nil => admit
| Vector.cons h' 0 _ => v
| Vector.cons h' (S len') t' =>
Vector.cons nat (h + h') _ (pt_aux h' _ t')
end.
Here, Coq fails with
The term "Vector.cons nat (h + h') (S len') (pt_aux h' len' t'0)" has type
"Vector.t nat (S (S len'))" while it is expected to have type
"Vector.t nat (S len)".
How can I tell Coq that (S (S len') = S len) ?
I first though that maybe I need a pattern matching function with type:
match_vec : n -> forall A, Vector.t A n -> option {Vector.t A (S n')
| S n' = n}
obviously this doesn't work, because I need to somehow apply this
function n'. I tried using `exists` like this `option (exists n',
{Vector.t A (S n') | S n' = n})` but no luck... Maybe what I'm trying
to do does not even make sense.
(I had asked a similar question here, I was trying to tell Coq that n
= S n' in successor case of pattern matching on natural number n, I
tried using similar techniques for solving this problem but couldn't
do anything useful)
Thanks..
Ömer Sinan Ağacan
http://osa1.net
- [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, Ömer Sinan Ağacan, 04/12/2014
- Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, Arthur Azevedo de Amorim, 04/12/2014
- Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, Ömer Sinan Ağacan, 04/13/2014
- Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, Abhishek Anand, 04/13/2014
- Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, AUGER Cédric, 04/13/2014
- Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, Arthur Azevedo de Amorim, 04/14/2014
