Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?
- To: coq-club AT inria.fr
- Cc: omeragacan AT gmail.com
- Subject: Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?
- Date: Sun, 13 Apr 2014 11:09:56 +0200
Le Sun, 13 Apr 2014 06:21:25 +0300,
Ömer Sinan Ağacan
<omeragacan AT gmail.com>
a écrit :
> Thanks for your answer, it worked! I don't understand how can this
> code work, though. Because pattern matching has different return type
> than the function.
Once your proof script is accepted, simply run "Print <term>." to see
it.
Lemma identity : forall A, A -> A.
Proof.
intros T.
intro t.
exact t.
Defined.
Print identity.
identity = fun (T : Type) (t : T) => t
: forall A : Type, A -> A
Argument scopes are [type_scope _]
Thus if you can do a proof script and you do not understand how to
write the term, you can read the Print output to get the idea.
> Also, I tried replacing `v'` with `_` and using `refine` tactic, but I
> didn't get `Vector h' 0 someFreshVar = v'` as hypothesis while filling
> the case with `as v'`. Why I never get this types of equalities in
> pattern matching?
> Thanks again.
> Ömer Sinan Ağacan
> http://osa1.net
- [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, Ömer Sinan Ağacan, 04/12/2014
- Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, Arthur Azevedo de Amorim, 04/12/2014
- Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, Ömer Sinan Ağacan, 04/13/2014
- Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, Abhishek Anand, 04/13/2014
- Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, AUGER Cédric, 04/13/2014
- Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, Arthur Azevedo de Amorim, 04/14/2014
