Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?
- To: coq club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?
- Date: Sun, 13 Apr 2014 06:21:25 +0300
Thanks for your answer, it worked! I don't understand how can this
code work, though. Because pattern matching has different return type
than the function.
Also, I tried replacing `v'` with `_` and using `refine` tactic, but I
didn't get `Vector h' 0 someFreshVar = v'` as hypothesis while filling
the case with `as v'`. Why I never get this types of equalities in
pattern matching?
Thanks again.
Ömer Sinan Ağacan
http://osa1.net
- [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, Ömer Sinan Ağacan, 04/12/2014
- Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, Arthur Azevedo de Amorim, 04/12/2014
- Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, Ömer Sinan Ağacan, 04/13/2014
- Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, Abhishek Anand, 04/13/2014
- Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, AUGER Cédric, 04/13/2014
- Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, Arthur Azevedo de Amorim, 04/14/2014
