Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?
- From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?
- Date: Sun, 13 Apr 2014 00:01:45 -0400
If you are not allergic to writing programs as proofs, here is what you can do (checked with Coq 8.4pl2):
Lemma pt_aux : forall (h : nat) len (v : Vector.t nat (S len)), Vector.t nat (S len).
Proof.
induction len as [ | hlen recursiveCall ]; intros.
- exact v.
- inversion v. apply (Vector.cons _ (h0+h)). apply recursiveCall. exact H0.
Defined.
Remember to end the proof with "Defined" instead of "Qed".
-- Abhishek
http://www.cs.cornell.edu/~aa755/On Sat, Apr 12, 2014 at 11:21 PM, Ömer Sinan Ağacan <omeragacan AT gmail.com> wrote:
Thanks for your answer, it worked! I don't understand how can this
code work, though. Because pattern matching has different return type
than the function.
Also, I tried replacing `v'` with `_` and using `refine` tactic, but I
didn't get `Vector h' 0 someFreshVar = v'` as hypothesis while filling
the case with `as v'`. Why I never get this types of equalities in
pattern matching?
Thanks again.
- [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, Ömer Sinan Ağacan, 04/12/2014
- Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, Arthur Azevedo de Amorim, 04/12/2014
- Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, Ömer Sinan Ağacan, 04/13/2014
- Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, Abhishek Anand, 04/13/2014
- Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, AUGER Cédric, 04/13/2014
- Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, Arthur Azevedo de Amorim, 04/14/2014
