[Coq-Club] nice evar tactics (was: Re: Prop smuggling (was: Re: Smart case analysis in Coq.))
- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] nice evar tactics (was: Re: Prop smuggling (was: Re: Smart case analysis in Coq.))
- Date: Wed, 23 Jul 2014 13:57:05 -0400
On 07/23/2014 12:14 PM, Jonathan wrote:
Oh - wait - context can be used for that:
Ltac name_evars :=
repeat match goal with |- context[?V] => is_evar V; set V end.
Hey, I like that! But now one has a bunch of hypotheses each with an evar as their value. Nicer, since now instantiate's funky numbering is no longer needed. But, is there a way to fill in the values of those evars without using instantiate? Hmmm:
Ltac assign name term :=
match goal with name := ?V : _ |- _ => unify V term end.
Cool! These tactics need to be dressed up a bit using Tactic Notation. But, now I think I can deal with the possible deprecation of instantiate.
-- Jonathan
I cleaned those tactics up and added a few more - attached.
-- Jonathan
Ltac name_evars id := repeat match goal with |- context[?V] => is_evar V; let H := fresh id in set (H:=V) in * end. Ltac name_evars_in hyp id := repeat match type of hyp with context[?V] => is_evar V; let H:=fresh id in set (H:=V) in *; move H at bottom end. Ltac name_evars_of type id := repeat match goal with |- context[?V] => is_evar V; match type of V with type => let H:= fresh id in set (H:=V) in * end end. Ltac name_evars_in_of hyp type id := repeat match type of hyp with context[?V] => is_evar V; match type of V with type => let H:=fresh id in set (H:=V) in *; move H at bottom end end. Ltac assign name term := match goal with H := ?V : _ |- _ => match H with name => unify V term end end. Ltac assign_any term := match goal with H := ?V : _ |- _ => is_evar V; unify V term end. Section Tests. Variable Foo : nat -> bool -> nat -> list nat -> Prop. Goal exists n b1 b2 m l, Foo n b1 m l -> Foo m (negb b2) n l. repeat eexists. intro H. name_evars_in_of H nat i0. name_evars_of bool b. name_evars_in H x0. assign b true. assign_any (0::1::2::nil)%list. assign i0 42. assign i1 13. assign x0 (negb b). Abort. End Tests.
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), (continued)
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jason Gross, 07/23/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jonathan, 07/23/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Arnaud Spiwack, 07/23/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Xavier Leroy, 07/23/2014
- [Coq-Club] nice evar tactics (was: Re: Prop smuggling (was: Re: Smart case analysis in Coq.)), Jonathan, 07/23/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Arnaud Spiwack, 07/24/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jonathan, 07/24/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jason Gross, 07/24/2014
