coq-club - Re: [Coq-Club] Rewrite does not work
  • From: Thomas Braibant <thomas.braibant AT gmail.com>
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Rewrite does not work
  • Date: Thu, 31 Jul 2014 19:33:05 +0200
One thing that could go wrong with a conversion check is that it might
be really expensive in some cases. Another problem is that a fix might
break some existing contribs ;).
In any case, I had a look at the code of omega, and it seems quite
easy indeed to implement this heavy-handed solution.
On Thu, Jul 31, 2014 at 6:48 PM, Xavier Leroy
<Xavier.Leroy AT inria.fr>
wrote:
> On 30/07/14 20:11, Jonathan wrote:
>> How about this stop-gap proposal: define an unfold hint db to which users
>> can add their own hints, and which is used by Coq in cases like rewrite and
>> omega (and I'm sure plenty of others). Or, slightly better - have a
>> setting
>> like "Add Implicit Autounfolds dbname" so that multiple different hint dbs
>> can be used.
> Thanks for the suggestion. It could work pretty well for my uses in
> CompCert, because I have relatively few type aliases and they get
> reused a lot. But Coq beginners would still be baffled, first by the
> mysterious failures of rewrite et al, then by the need to build an
> unfold hint db...
> Why just a stop-gap and not a proper fix? Being curious, I looked at
> the implementation of "omega" to undestand why it skips equalities at
> types that are aliases of Z. The algorithm is, as far as I
> understand:
> - normalize the type part of the equality using "pf_nf"
> (i.e. "pf_reduce simpl") (apparently something that doesn't unfold
> definitions);
> - test for equality with the "Z" type constructor.
> Why not just a conversion check instead of "normalize (incompletely)
> then test for equality"? What could possibly go wrong?
> Apologies for being probably naive and definitely heavy-handed with this
> issue, but I strongly feel that a number of basic tactics of Coq could
> use some love. That they have been clunky for the last two decades
> and that power users learned to work around this clunkiness is no
> reason for status quo.
> - Xavier
