- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Rewrite does not work
- Date: Thu, 31 Jul 2014 14:20:07 -0400
On 07/31/2014 01:33 PM, Jason Gross wrote:
Would something like the feature request I made for more opacity levels
<https://coq.inria.fr/bugs/show_bug.cgi?id=3389> fix this problem?
-Jason
It would certainly make some things easier. Although I don't fully understand what distinguishes all those new levels, I can see that some (like expand_invisible) would be helpful.
But, although I brought up Strategy levels, I did so somewhat half-heartedly. They seem very ad-hoc, the kind of thing that one doesn't mind so much in syntax (as with Notation levels), but wonders about maybe causing problems in semantics. Giving names to levels helps vs. just numbers, though - but maybe not enough.
I also want to make a comment about decision procedures like omega and lia: I think it is hard to see cases for decision procedures where preventing conversion (at least when allowing it wouldn't cause termination or severe performance problems) is a good thing. But, consider a tactic like ring_simplify. One can easily imagine cases involving defining constants (in terms of ring operations) that one then wants to remain opaque to ring_simplify, so that the result isn't over-simplified.
-- Jonathan
- Re: [Coq-Club] Rewrite does not work, (continued)
- Re: [Coq-Club] Rewrite does not work, Jonathan, 07/27/2014
- Re: [Coq-Club] Rewrite does not work, Pierre-Marie Pédrot, 07/28/2014
- Re: [Coq-Club] Rewrite does not work, Marcus Ramos, 07/29/2014
- Re: [Coq-Club] Rewrite does not work, Cedric Auger, 07/29/2014
- Re: [Coq-Club] Rewrite does not work, Enrico Tassi, 07/29/2014
- Re: [Coq-Club] Rewrite does not work, Xavier Leroy, 07/30/2014
- Re: [Coq-Club] Rewrite does not work, Jonathan, 07/30/2014
- Re: [Coq-Club] Rewrite does not work, Xavier Leroy, 07/31/2014
- Re: [Coq-Club] Rewrite does not work, Jonathan, 07/31/2014
- Re: [Coq-Club] Rewrite does not work, Jason Gross, 07/31/2014
- Re: [Coq-Club] Rewrite does not work, Randy Pollack, 07/31/2014
- Re: [Coq-Club] Rewrite does not work, Thomas Braibant, 07/31/2014
- Re: [Coq-Club] Rewrite does not work, Maxime Dénès, 07/31/2014
- Re: [Coq-Club] Rewrite does not work, Laurence Rideau, 07/31/2014
- Re: [Coq-Club] Rewrite does not work, Frédéric Besson, 07/31/2014
