- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Rewrite does not work
- Date: Thu, 31 Jul 2014 18:33:31 +0100
Would something like the feature request I made for more opacity levels fix this problem?
-Jason
On Thu, Jul 31, 2014 at 6:28 PM, Jonathan <jonikelee AT gmail.com> wrote:
On 07/31/2014 12:48 PM, Xavier Leroy wrote:What would a proper fix be? Sometimes, you want rewrite (and other tactics) to not do certain conversions. That means that something is needed to distinguish between the conversions you want to be automatic and those you don't.
On 30/07/14 20:11, Jonathan wrote:
How about this stop-gap proposal: define an unfold hint db to which usersThanks for the suggestion. It could work pretty well for my uses in
can add their own hints, and which is used by Coq in cases like rewrite and
omega (and I'm sure plenty of others). Or, slightly better - have a setting
like "Add Implicit Autounfolds dbname" so that multiple different hint dbs
can be used.
CompCert, because I have relatively few type aliases and they get
reused a lot. But Coq beginners would still be baffled, first by the
mysterious failures of rewrite et al, then by the need to build an
unfold hint db...
Why just a stop-gap and not a proper fix?
Maybe use Strategy levels somehow?
-- Jonathan
- Re: [Coq-Club] Rewrite does not work, (continued)
- Re: [Coq-Club] Rewrite does not work, AUGER Cédric, 07/27/2014
- Re: [Coq-Club] Rewrite does not work, Jonathan, 07/27/2014
- Re: [Coq-Club] Rewrite does not work, Pierre-Marie Pédrot, 07/28/2014
- Re: [Coq-Club] Rewrite does not work, Marcus Ramos, 07/29/2014
- Re: [Coq-Club] Rewrite does not work, Cedric Auger, 07/29/2014
- Re: [Coq-Club] Rewrite does not work, Enrico Tassi, 07/29/2014
- Re: [Coq-Club] Rewrite does not work, Xavier Leroy, 07/30/2014
- Re: [Coq-Club] Rewrite does not work, Jonathan, 07/30/2014
- Re: [Coq-Club] Rewrite does not work, Xavier Leroy, 07/31/2014
- Re: [Coq-Club] Rewrite does not work, Jonathan, 07/31/2014
- Re: [Coq-Club] Rewrite does not work, Jason Gross, 07/31/2014
- Re: [Coq-Club] Rewrite does not work, Randy Pollack, 07/31/2014
- Re: [Coq-Club] Rewrite does not work, Thomas Braibant, 07/31/2014
- Re: [Coq-Club] Rewrite does not work, Maxime Dénès, 07/31/2014
- Re: [Coq-Club] Rewrite does not work, Laurence Rideau, 07/31/2014
- Re: [Coq-Club] Rewrite does not work, Frédéric Besson, 07/31/2014
