- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Rewrite does not work
- Date: Fri, 1 Aug 2014 19:35:04 +0200
On Fri, Aug 01, 2014 at 06:21:40PM +0200, Hugo Herbelin wrote:
> example being in rewriting "x * (y * z)" which started to match
> expressions of the form "t * power x 2". I have no idea how common
> this would occur in arbitrary developments.
This is expected, ssr does some magic for that specific case.
See http://hal.inria.fr/docs/00/66/98/05/PDF/rew.pdf section 3.2.
Actually the implementation in the plugin is very ugly, and I probably
still have a unfinished branch somewhere with a better coding of the
same idea.
Ciao,
Enrico Tassi
- Re: [Coq-Club] evil evars (was Re: Rewrite does not work), (continued)
- Re: [Coq-Club] evil evars (was Re: Rewrite does not work), Jonathan, 08/02/2014
- Re: [Coq-Club] evil evars (was Re: Rewrite does not work), Daniel Schepler, 08/02/2014
- Re: [Coq-Club] Rewrite does not work, Jonathan, 08/01/2014
- Re: [Coq-Club] Rewrite does not work, Enrico Tassi, 08/01/2014
- [Coq-Club] why backward chain (ergo evars) (was Re: Rewrite does not work), Jonathan, 08/01/2014
