- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] evil evars (was Re: Rewrite does not work)
- Date: Sat, 02 Aug 2014 12:19:40 -0400
On 08/02/2014 11:38 AM, Jonathan wrote:
So, I would guess that what instantiate is doing is reaching into the dependent subgoal to do its work - ignoring whatever is going on (such as name changing and the like) in the other subgoals. If that is the correct behavior, might expect "Display Existential Variable Instances" to do the same, but it doesn't. Alternately, perhaps the dependent subgoal should undergo renamings as they occur in the other subgoals? But, how could you do this, as there could be multiple other subgoals in which the evar exists, and they can all name the same things differently? Or, keep track of a renaming map between the dependent subgoal and each of the others? Or, always skolemize - which is equivalent to reverting all in the dependent subgoal as soon as it is introduced, so that they have no names to confuse?
-- Jonathan
A further note to whomever might consider fixing evars - please keep in mind that it's not just renaming that is the problem. Renaming might be the least of the problem, as illustrated here:
Goal forall (n:nat), True.
intros.
evar (i:nat).
apply id in n.
Fail instantiate (1:=n) in (Value of i).
If Coq is to allow true backward chaining, then it has to give evars more freedom than this.
-- Jonathan
- Re: [Coq-Club] Rewrite does not work, Enrico Tassi, 08/01/2014
- Re: [Coq-Club] Rewrite does not work, Matthieu Sozeau, 08/01/2014
- <Possible follow-up(s)>
- Re: [Coq-Club] Rewrite does not work, Jonathan, 08/01/2014
- Re: [Coq-Club] Rewrite does not work, Cedric Auger, 08/01/2014
- [Coq-Club] evil evars (was Re: Rewrite does not work), Jonathan, 08/01/2014
- Re: [Coq-Club] evil evars (was Re: Rewrite does not work), Matthieu Sozeau, 08/01/2014
- Re: [Coq-Club] evil evars (was Re: Rewrite does not work), Cédric, 08/02/2014
- Re: [Coq-Club] evil evars (was Re: Rewrite does not work), Jonathan, 08/02/2014
- Re: [Coq-Club] evil evars (was Re: Rewrite does not work), Daniel Schepler, 08/02/2014
- [Coq-Club] why backward chain (ergo evars) (was Re: Rewrite does not work), Jonathan, 08/01/2014
