- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] evil evars (was Re: Rewrite does not work)
- Date: Sat, 02 Aug 2014 11:38:52 -0400
On 08/02/2014 02:56 AM, Cédric wrote:
By the way, Jonathan asked if there was a bug in the variable renaming with
respect to evars.
I think it is the case as:
Hypothesis P : nat -> nat -> Prop.
Hypothesis Q : Prop.
Goal forall (n m : nat), Q.
intros n.
evar (i:nat).
intros m.
cut (P m i).
intros H.
revert H.
revert i.
revert n.
intros p.
intro i.
outputs:
2 subgoal
m : nat
p : nat
i := ?7 (* [p] *) : nat
______________________________________(1/2)
P m i -> Q
______________________________________(2/2)
P m i
and still "instantiace (1:=p) in (Value of i)" does not work, while the
display
clearly prints that it can only depend on 'p', while the old name 'n' still
works (and uses 'p' in fact).
Cédric AUGER
Also note that "instantiate (1:=n) in (Value of i)" does work. What may be happening (I'm straining to see into this black box) is perhaps made clearer using the "refine-born" evars in the trunk, with their dependent subgoals:
intros n.
refine (let i:=_:nat in _). shelve.
intros m.
cut (P m i).
intros H.
revert H.
revert i.
revert n.
intros p.
intro i.
Unshelve.
Focus 3.
This dependent subgoal corresponding to the evar still has the hypothesis named n:
1 subgoal
n : nat
______________________________________(1/1)
nat
And, "exact n" works here.
So, I would guess that what instantiate is doing is reaching into the dependent subgoal to do its work - ignoring whatever is going on (such as name changing and the like) in the other subgoals. If that is the correct behavior, might expect "Display Existential Variable Instances" to do the same, but it doesn't. Alternately, perhaps the dependent subgoal should undergo renamings as they occur in the other subgoals? But, how could you do this, as there could be multiple other subgoals in which the evar exists, and they can all name the same things differently? Or, keep track of a renaming map between the dependent subgoal and each of the others? Or, always skolemize - which is equivalent to reverting all in the dependent subgoal as soon as it is introduced, so that they have no names to confuse?
-- Jonathan
- Re: [Coq-Club] Rewrite does not work, Enrico Tassi, 08/01/2014
- Re: [Coq-Club] Rewrite does not work, Matthieu Sozeau, 08/01/2014
- <Possible follow-up(s)>
- Re: [Coq-Club] Rewrite does not work, Jonathan, 08/01/2014
- Re: [Coq-Club] Rewrite does not work, Cedric Auger, 08/01/2014
- [Coq-Club] evil evars (was Re: Rewrite does not work), Jonathan, 08/01/2014
- Re: [Coq-Club] evil evars (was Re: Rewrite does not work), Matthieu Sozeau, 08/01/2014
- Re: [Coq-Club] evil evars (was Re: Rewrite does not work), Cédric, 08/02/2014
- Re: [Coq-Club] evil evars (was Re: Rewrite does not work), Jonathan, 08/02/2014
- Re: [Coq-Club] evil evars (was Re: Rewrite does not work), Daniel Schepler, 08/02/2014
- [Coq-Club] why backward chain (ergo evars) (was Re: Rewrite does not work), Jonathan, 08/01/2014
