- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] evil evars (was Re: Rewrite does not work)
- Date: Sat, 02 Aug 2014 12:58:33 -0400
On 08/02/2014 12:45 PM, Daniel Schepler wrote:
On Sat, Aug 2, 2014 at 9:19 AM, Jonathan
<jonikelee AT gmail.com>
wrote:
A further note to whomever might consider fixing evars - please keep in mindBut of course, it can't allow too much freedom or something like this
that it's not just renaming that is the problem. Renaming might be the
least of the problem, as illustrated here:
Goal forall (n:nat), True.
intros.
evar (i:nat).
apply id in n.
Fail instantiate (1:=n) in (Value of i).
If Coq is to allow true backward chaining, then it has to give evars more
freedom than this.
would fail only at Qed time:
Goal exists n:nat, forall m:nat, m <= n.
Proof.
eexists.
intro m.
eapply le_n.
Qed.
(Sorry if I'm pointing out the obvious here.)
Certainly, cycles have to be excluded! That might point in the direction of a better solution: keep a dependency graph and use it to prevent evar instantiations that would introduce cycles. Probably over-simplifying - I'm sure there are other things that must be prevented as well. Oh - here's one: you must prevent a non-Prop evar created in a non-Prop context from being instantiated in or following the transformation of the goal into a Prop context, else you could violate Coq's Prop/Type separation.
-- Jonathan
- Re: [Coq-Club] Rewrite does not work, (continued)
- Re: [Coq-Club] Rewrite does not work, Enrico Tassi, 08/01/2014
- Re: [Coq-Club] Rewrite does not work, Jonathan, 08/01/2014
- Re: [Coq-Club] Rewrite does not work, Cedric Auger, 08/01/2014
- [Coq-Club] evil evars (was Re: Rewrite does not work), Jonathan, 08/01/2014
- Re: [Coq-Club] evil evars (was Re: Rewrite does not work), Matthieu Sozeau, 08/01/2014
- Re: [Coq-Club] evil evars (was Re: Rewrite does not work), Cédric, 08/02/2014
- Re: [Coq-Club] evil evars (was Re: Rewrite does not work), Jonathan, 08/02/2014
- Re: [Coq-Club] evil evars (was Re: Rewrite does not work), Daniel Schepler, 08/02/2014
- [Coq-Club] why backward chain (ergo evars) (was Re: Rewrite does not work), Jonathan, 08/01/2014
