- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Rewrite does not work
- Date: Fri, 01 Aug 2014 16:28:44 -0400
On 08/01/2014 11:38 AM, Enrico Tassi wrote:
On Fri, Aug 01, 2014 at 11:02:48AM -0400, Jonathan wrote:
Sorry for being naive, but I seldom have evar around even if ISsr POV is that evars are constants, no ssr tactic should let youPerhaps the occurrence of evars is much more likely when using backward
instantiate them, but should not "destroy" them either. We hardly use
evars in our goals.
chaining.
backchain. Can you give me an example of typical situation in which
you generate a new evar by backchaining?
Best
An extremely simplistic case of perhaps the most common culprit: econstructor (and equivalent uses of eapply, refine, etc. that omit arguments in favor of subgoals - i.e. backward chain):
Variable P : nat -> Prop.
Inductive mytype : Type :=
| Mytype(x : nat)(px : P x) : mytype.
Goal mytype.
econstructor.
produces the goal like:
1 subgoals
, subgoal 1 (ID 4)
P ?3
Consider similar construction of instances of types with much more complex parameterization/indexation. The evars occur in the subgoals corresponding to omitted (in the constructor application) dependently constrained fields in the constructor. In the above, if we eliminate the px field, the subgoal generated is just "nat" - no evars.
-- Jonathan
- Re: [Coq-Club] Rewrite does not work, (continued)
- Re: [Coq-Club] Rewrite does not work, Jonathan, 08/01/2014
- Re: [Coq-Club] Rewrite does not work, Cedric Auger, 08/01/2014
- [Coq-Club] evil evars (was Re: Rewrite does not work), Jonathan, 08/01/2014
- Re: [Coq-Club] evil evars (was Re: Rewrite does not work), Matthieu Sozeau, 08/01/2014
- Re: [Coq-Club] evil evars (was Re: Rewrite does not work), Cédric, 08/02/2014
- Re: [Coq-Club] evil evars (was Re: Rewrite does not work), Jonathan, 08/02/2014
- Re: [Coq-Club] evil evars (was Re: Rewrite does not work), Daniel Schepler, 08/02/2014
- Re: [Coq-Club] Rewrite does not work, Enrico Tassi, 08/01/2014
- [Coq-Club] why backward chain (ergo evars) (was Re: Rewrite does not work), Jonathan, 08/01/2014
