- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] pattern matching surprise
- Date: Sun, 03 Aug 2014 13:44:16 +0200
Le Sun, 03 Aug 2014 13:17:26 +0200, Matej Kosik <5764c029b688c1c0d24a2e97cd764f AT gmail.com> a écrit:
Hi,
I would like to ask why if I introduce this definition:
(* CoqArt, Section 6.1.1 (pg 138) *)
Inductive month : Set :=
| January : month | February : month | March : month | April : month
| May : month | June : month | July : month | August : month
| September : month | October : month | November : month | December : month.
and then I try to define a function in the following way:
(* Exercise 6.5 (pg 144) *)
Definition month_has_even_number_of_days'' (leap:bool) (m:month) :=
match m with
| January | March | May | July | August | October | December => false
| Feburary => negb leap
| April | June | September | November => true
end.
then I am getting a complaint:
Toplevel input, characters 227-270:
Despite me tring to do fairly simple thing, the output thoroughly surprised me.
Is the above response plausible? Why?
Probably because you mistyped "February" in "Feburary", thus "Feburary" is considered as a variable matching all other cases. Then April, June, September and November are considered already treated by "Feburary"
A complementary question: why does Coq admit this:
Definition month_with_even_number_of_days''' (leap:bool) (m:month) :=
match m with
end.
instead of rejecting it due to cases that are not covered?
Because you continue to mistype February, and it is considered a variable matching all other cases.
<SIDENOTE>
This:
Definition month_has_even_number_of_days (leap:bool) (m:month) :=
match m with
| January => false
| February => negb leap
| March => false
| April => true
| May => false
| June => true
| July => false
| August => false
| September => true
| October => false
| November => true
| December => false
end.
as well as this:
Definition month_has_even_number_of_days' (leap:bool) :=
month_rec (fun _ => bool)
false (* January *)
(negb leap) (* February *)
false (* March *)
true (* April *)
false (* May *)
true (* June *)
false (* July *)
false (* August *)
true (* September *)
false (* October *)
true (* November *)
false. (* December *)
works as expected.
If I omit some case, Coq correctly identifies it and complains.
If I provide a superfluous case, Coq correctly identifies it and complains.
</SIDENOTE>
Cédric AUGER
- [Coq-Club] pattern matching surprise, Matej Kosik, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Cédric, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Vladimir Voevodsky, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Gabriel Scherer, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Matej Kosik, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Jonathan, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Michel Levy, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Hugo Herbelin, 08/03/2014
