- To: coq-club AT inria.fr, Cédric <sedrikov AT gmail.com>
- Cc: "Prof. Vladimir Voevodsky" <vladimir AT ias.edu>
- Subject: Re: [Coq-Club] pattern matching surprise
- Date: Sun, 3 Aug 2014 19:49:25 +0800
What kind of syntax "match" has if placing random garbage in it does not
generate an error message?
V.
On Aug 3, 2014, at 7:44 PM, Cédric
wrote:
> Le Sun, 03 Aug 2014 13:17:26 +0200, Matej Kosik
> <5764c029b688c1c0d24a2e97cd764f AT gmail.com>
> a écrit:
>> Hi,
>> I would like to ask why if I introduce this definition:
>> (* CoqArt, Section 6.1.1 (pg 138) *)
>> Inductive month : Set :=
>> | January : month | February : month | March : month | April : month
>> | May : month | June : month | July : month | August : month
>> | September : month | October : month | November : month | December :
>> month.
>> and then I try to define a function in the following way:
>> (* Exercise 6.5 (pg 144) *)
>> Definition month_has_even_number_of_days'' (leap:bool) (m:month) :=
>> match m with
>> | January | March | May | July | August | October | December => false
>> | Feburary => negb leap
>> | April | June | September | November => true
>> end.
>> then I am getting a complaint:
>> Toplevel input, characters 227-270:
>> Despite me tring to do fairly simple thing, the output thoroughly
>> surprised me.
>> Is the above response plausible? Why?
> Probably because you mistyped "February" in "Feburary", thus "Feburary" is
> considered as a variable matching all other cases. Then April, June,
> September and November are considered already treated by "Feburary"
>> A complementary question: why does Coq admit this:
>> Definition month_with_even_number_of_days''' (leap:bool) (m:month) :=
>> match m with
>> end.
>> instead of rejecting it due to cases that are not covered?
> Because you continue to mistype February, and it is considered a variable
>> <SIDENOTE>
>> This:
>> Definition month_has_even_number_of_days (leap:bool) (m:month) :=
>> match m with
>> | January => false
>> | February => negb leap
>> | March => false
>> | April => true
>> | May => false
>> | June => true
>> | July => false
>> | August => false
>> | September => true
>> | October => false
>> | November => true
>> | December => false
>> end.
>> as well as this:
>> Definition month_has_even_number_of_days' (leap:bool) :=
>> month_rec (fun _ => bool)
>> false (* January *)
>> (negb leap) (* February *)
>> false (* March *)
>> true (* April *)
>> false (* May *)
>> true (* June *)
>> false (* July *)
>> false (* August *)
>> true (* September *)
>> false (* October *)
>> true (* November *)
>> false. (* December *)
>> works as expected.
>> If I omit some case, Coq correctly identifies it and complains.
>> If I provide a superfluous case, Coq correctly identifies it and complains.
>> </SIDENOTE>
> Cédric AUGER
signature.asc
Description: Message signed with OpenPGP using GPGMail
- [Coq-Club] pattern matching surprise, Matej Kosik, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Cédric, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Vladimir Voevodsky, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Gabriel Scherer, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Matej Kosik, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Jonathan, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Michel Levy, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Hugo Herbelin, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Jason Gross, 08/03/2014
