- To: coq-club AT inria.fr, Michel Levy <michel.levy1948 AT gmail.com>
- Cc: "Prof. Vladimir Voevodsky" <vladimir AT ias.edu>
- Subject: Re: [Coq-Club] pattern matching surprise
- Date: Sun, 3 Aug 2014 20:55:26 +0800
Ok. Here is less complex code:
Inductive un : Type := .
Definition nonsense ( x : un ) := match x with y => 0 end .
Is this supposed to make sense?
If so then what is "y" in the term "match x with y => 0 end "? Is it a
variable? Is it a free variable or a bound variable?
PS ... and if I write this:
Definition nonsense ( x : un ) := match x with y + 2 => 0 end .
I get this:
> Toplevel input, characters 20-83:
> Anomaly: Uncaught exception Not_found(_). Please report.
(I am running trunk).
On Aug 3, 2014, at 8:12 PM, Michel Levy
wrote:
> On 03/08/2014 13:44, Cédric wrote:
>> Le Sun, 03 Aug 2014 13:17:26 +0200, Matej Kosik
>> <5764c029b688c1c0d24a2e97cd764f AT gmail.com>
>> a écrit:
>>> Hi,
>>> I would like to ask why if I introduce this definition:
>>> (* CoqArt, Section 6.1.1 (pg 138) *)
>>> Inductive month : Set :=
>>> | January : month | February : month | March : month | April :
>>> month
>>> | May : month | June : month | July : month | August
>>> : month
>>> | September : month | October : month | November : month |
>>> December : month.
>>> and then I try to define a function in the following way:
>>> (* Exercise 6.5 (pg 144) *)
>>> Definition month_has_even_number_of_days'' (leap:bool) (m:month) :=
>>> match m with
>>> | January | March | May | July | August | October | December =>
>>> false
>>> | Feburary => negb leap
>>> | April | June | September | November => true
>>> end.
>>> then I am getting a complaint:
>>> Toplevel input, characters 227-270:
>>> Despite me tring to do fairly simple thing, the output thoroughly
>>> surprised me.
>>> Is the above response plausible? Why?
>> Probably because you mistyped "February" in "Feburary", thus
>> "Feburary" is considered as a variable matching all other cases. Then
>> April, June, September and November are considered already treated by
>> "Feburary"
>>> A complementary question: why does Coq admit this:
>>> Definition month_with_even_number_of_days''' (leap:bool) (m:month) :=
>>> match m with
>>> false
>>> end.
>>> instead of rejecting it due to cases that are not covered?
>> Because you continue to mistype February, and it is considered a
> I confirm the diagnostic of Cédric : Feburary is a variable matching all
> other cases.
> A good way to verify this is to print the definition of
> month_with_even_number_of_days''' with
> Print month_with_even_number_of_days'''.
> email :
> http://membres-liglab.imag.fr/michel.levy
signature.asc
Description: Message signed with OpenPGP using GPGMail
- [Coq-Club] pattern matching surprise, Matej Kosik, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Cédric, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Vladimir Voevodsky, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Gabriel Scherer, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Matej Kosik, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Jonathan, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Michel Levy, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Hugo Herbelin, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Jason Gross, 08/03/2014
