coq-club - Re: [Coq-Club] pattern matching surprise
  • From: Gabriel Scherer <gabriel.scherer AT gmail.com>
  • To: Coq Club <coq-club AT inria.fr>
  • Cc: Michel Levy <michel.levy1948 AT gmail.com>, "Prof. Vladimir Voevodsky" <vladimir AT ias.edu>
  • Subject: Re: [Coq-Club] pattern matching surprise
  • Date: Sun, 3 Aug 2014 16:51:59 +0200
> Definition nonsense ( x : un ) := match x with y => 0 end .
> Is this supposed to make sense?
This makes perfect sense.
> If so then what is "y" in the term "match x with y => 0 end "? Is it a
> variable? Is it a free variable or a bound variable?
"y" is a variable in binding position. I would call
"bound variable" the uses under a binder; this is not a use but a
definition.
Some beginners find this awkward. In particular if you write:
Definition y := 0.
Definition awkward x := match x with y => true | _ => false.
They would expect the 'y' in a pattern to correspond to an equality
test to the existing 'y' variable, while it in fact is a binder that
catches all case (so the "| _" is an error). I've seen enough
beginners make this confusion to conclude that this syntax is maybe a
bit too clever for its own good, at least when the binder shadows an
existing variable. I know of no better alternative, though.
Furthermore, in a dependently typed language, the interpretation of
pattern-y as an equality test would be a dubious design choice,
because equality is not an easy notion.
On Sun, Aug 3, 2014 at 2:55 PM, Vladimir Voevodsky
wrote:
> Ok. Here is less complex code:
> Inductive un : Type := .
> PS ... and if I write this:
> Definition nonsense ( x : un ) := match x with y + 2 => 0 end .
> I get this:
>> Toplevel input, characters 20-83:
>> Anomaly: Uncaught exception Not_found(_). Please report.
> (I am running trunk).
> On Aug 3, 2014, at 8:12 PM, Michel Levy
> wrote:
>> On 03/08/2014 13:44, Cédric wrote:
>>> Le Sun, 03 Aug 2014 13:17:26 +0200, Matej Kosik
>>> <5764c029b688c1c0d24a2e97cd764f AT gmail.com>
>>> a écrit:
>>>> Hi,
>>>> I would like to ask why if I introduce this definition:
>>>> (* CoqArt, Section 6.1.1 (pg 138) *)
>>>> Inductive month : Set :=
>>>> | January : month | February : month | March : month | April :
>>>> month
>>>> | May : month | June : month | July : month | August
>>>> : month
>>>> | September : month | October : month | November : month |
>>>> December : month.
>>>> and then I try to define a function in the following way:
>>>> (* Exercise 6.5 (pg 144) *)
>>>> Definition month_has_even_number_of_days'' (leap:bool) (m:month) :=
>>>> match m with
>>>> | January | March | May | July | August | October | December =>
>>>> false
>>>> | Feburary => negb leap
>>>> | April | June | September | November => true
>>>> end.
>>>> then I am getting a complaint:
>>>> Toplevel input, characters 227-270:
>>>> Despite me tring to do fairly simple thing, the output thoroughly
>>>> surprised me.
>>>> Is the above response plausible? Why?
>>> Probably because you mistyped "February" in "Feburary", thus
>>> "Feburary" is considered as a variable matching all other cases. Then
>>> April, June, September and November are considered already treated by
>>> "Feburary"
>>>> A complementary question: why does Coq admit this:
>>>> Definition month_with_even_number_of_days''' (leap:bool) (m:month) :=
>>>> match m with
>>>> false
>>>> end.
>>>> instead of rejecting it due to cases that are not covered?
>>> Because you continue to mistype February, and it is considered a
>> I confirm the diagnostic of Cédric : Feburary is a variable matching all
>> other cases.
>> A good way to verify this is to print the definition of
>> month_with_even_number_of_days''' with
>> Print month_with_even_number_of_days'''.
>> email :
>> http://membres-liglab.imag.fr/michel.levy
