- From: Matej Kosik <5764c029b688c1c0d24a2e97cd764f AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] pattern matching surprise
- Date: Sun, 03 Aug 2014 16:00:13 +0100
On 03/08/14 13:06, Gabriel Scherer wrote:
> One man's random garbage is another's perfectly valid variable name.
> Matej was, however, getting an error message, highlighting the extra
> cases after the free variable.
>> Error: this clause is redundant.
> It's delicate to design languages with pattern-matching that never
> behave confusingly. In OCaml, variables may not start with an
> uppercase, precisely to avoid this problem. In some other languages,
> variables are not patterns by themselves, you have to use some
> explicit marker to turn a variable in a binder pattern. That's also
> rather heavy.
My caution against typos in variable names was dulled by Ocaml.
There, instead of:
Toplevel input, characters ...-...:
> | April | June | September | November => true
I would get:
| Feburary => negb leap
Warning: Unused variable "Feburary"
Error: This clause is redundant.
which, however simple it sounds, would lead me to the right direction.
Until unused variables are detected by Coq automatically, I just have to be
more careful.
Thank you guys.
- [Coq-Club] pattern matching surprise, Matej Kosik, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Cédric, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Vladimir Voevodsky, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Gabriel Scherer, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Matej Kosik, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Jonathan, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Michel Levy, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Hugo Herbelin, 08/03/2014
- Re: [Coq-Club] pattern matching surprise, Jason Gross, 08/03/2014
