- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] what exactly are the Prop analysis rules?
- Date: Sun, 03 Aug 2014 11:47:10 -0400
I thought that just the kind of goal (Prop vs, non-Prop), along with the particulars of a specific Prop (single constructor/no info vs otherwise), determine whether or not that Prop can be analyzed in a context. But then I stumbled on this (works in the trunk):
Goal forall (A : Prop) (P : A -> Prop),
(exists x, P x) -> {x : A | P x }.
intros A P H.
destruct H. eexists. exact H.
Qed.
(exists x, P x) -> nat.
intros A P H.
Fail destruct H.
Abort.
What is so different about a nat vs. a sig that allows the analysis of the ex H in the sig goal but not the nat goal?
More importantly, why prevent the destruct in the nat goal if it is allowed in the sig goal?
-- Jonathan
- [Coq-Club] what exactly are the Prop analysis rules?, Jonathan, 08/03/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Pierre-Marie Pédrot, 08/03/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Jonathan, 08/03/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Arnaud Spiwack, 08/04/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Jonathan, 08/04/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Cédric, 08/03/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Maxime Dénès, 08/03/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Cédric, 08/04/2014
