coq-club - Re: [Coq-Club] what exactly are the Prop analysis rules?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] what exactly are the Prop analysis rules?
  • Date: Mon, 04 Aug 2014 13:07:52 -0400
On 08/04/2014 05:41 AM, Arnaud Spiwack wrote:
So, what exactly is not being able to destruct H in the nat goal
preventing, when I can just do this:
The limitations of pattern matching over proposition have two goals:
- Keeping compatibility with proof irrelevance (which is one way of
ensuring that extraction can safely erase propositions (it is not that
simple in practice, though)).
- Preventing False from being provable
The former is what prevents [P\/Q] from being analysable in a non-[Prop]
context. Otherwise, we would have, say [True\/True] is isomorphic to
[bool].
Right - instead, {True}+{True} is isomorphic to bool. That is probably a good source of confusion. But in terms of information content, it is easier to understand: bool contains a bit of information in its "value", while {True}+{True} contains a bit of information in discrimination between its two non-Prop-kinded constructors - and these lines completely blur, as the "value" of bool really just amounts to discrimination between its own two non-Prop-kinded constructors, and nothing more.
But, True \/ True is isomorphic to True. And False \/ P is isomorphic to P. So, allowing analysis of either in a non-Prop context shouldn't impact proof irrelevance in any way. I am not suggesting that Coq should strive to do ths - I was just looking for the rule Coq is using. At this point in the discussion, I would guess the rule is something like that the term is considered analyzable or not independently of its subterms.
In particular proof-irrelevance would be false (this is basically
what Guillaume is saying above). Note that, in the impredicative version of
[Set], [P+Q] is indeed a set (for [P] and [Q] in Set). It's really specific
to the semantics of [Prop].
The latter is more imperative (and holds for impredicative [Set] as well),
and prevents [exists x:A,P] from being analysable in a non-[Prop] context.
The reason is fairly technical but has been known at least since the late
eighties (see Thierry Coquand's *An analysis of Girard's paradox*).
Basically, being able to eliminate over existential allows for an encoding
of Burali-Forti's paradox akin to Girard's paradox in System U (or even
easier in Type:Type). Well… let's come entirely honest: this only prevents
elimination of existential towards sorts which are above [Prop] (that is
[Type]). But we cannot eliminate towards [Set] either because [exists
b:bool, if b then P else Q] is isomorphic to [P\/Q], so we are back to the
previous case.
None of the above applies to a conjunction however. There is no property
lost from being able to analyse [A/\B] in a non-[Prop] context (apart from
creating absolutely horrendous bugs and complications in the extraction
procedure, of course, but this is another story). So, in fact, for [A] and
[B] in [Prop], [A/\B] is isomorphic to [A*B]. Coq takes this remark one
step further and considers that [A*B] is, in this case, a [Prop] (which
creates further horrendous bugs an complication in the extraction
procedure, but this is still another story). It is the same which happens
to [sig] in your example above.
Now that I know this can happen - that Coq can "demote" certain things into Prop despite their declaration in Type - I think that this is a very good thing. It is just a little hard to predict when it will happen vs. not. It reminds me of the developments in Idris towards compiler-determined erasability beyond declaration-based erasability. As erasability is a topic of interest to me, I am very happy to see further developments in this area.
Thanks for the explanation, Arnaud!
-- Jonathan
