- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] what exactly are the Prop analysis rules?
- Date: Sun, 03 Aug 2014 12:17:22 -0400
I think this is actually a bug of destruct. The following works:
Goal forall (A : Prop) (P : A -> Prop),
(exists x, P x) -> ({x : A | P x } : Type).
intros A P H.
refine (match H with ex_intro _ a p => _ end).
exists a. exact p.
Qed.
I don't think this example is directly connected to sort polymorphism.
The reason why this is allowed is the so-called singleton elimination rule. Of course, it relies critically on the fact that A is in Prop.
Maxime.
On 08/03/2014 12:02 PM, Cédric wrote:
Le Sun, 03 Aug 2014 17:47:10 +0200, Jonathan <jonikelee AT gmail.com> a écrit:
I thought that just the kind of goal (Prop vs, non-Prop), along with the particulars of a specific Prop (single constructor/no info vs otherwise), determine whether or not that Prop can be analyzed in a context. But then I stumbled on this (works in the trunk):
(exists x, P x) -> {x : A | P x }.
intros A P H.
destruct H. eexists. exact H.
Qed.
(exists x, P x) -> nat.
intros A P H.
Fail destruct H.
Abort.
What is so different about a nat vs. a sig that allows the analysis of the ex H in the sig goal but not the nat goal?
More importantly, why prevent the destruct in the nat goal if it is allowed in the sig goal?
Compare these variants, and you will probably have your answer.
(exists x, P x) -> ({x : A | P x } : Prop).
intros A P H.
Qed.
intros A P H.
Qed.
Coq has a non obvious system to tell what is in Prop and what is in Type.
-- Jonathan
- [Coq-Club] what exactly are the Prop analysis rules?, Jonathan, 08/03/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Pierre-Marie Pédrot, 08/03/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Jonathan, 08/03/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Arnaud Spiwack, 08/04/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Jonathan, 08/04/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Cédric, 08/03/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Maxime Dénès, 08/03/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Cédric, 08/04/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Guillaume Melquiond, 08/04/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Maxime Dénès, 08/04/2014
