coq-club - Re: [Coq-Club] what exactly are the Prop analysis rules?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] what exactly are the Prop analysis rules?
  • Date: Sun, 03 Aug 2014 19:59:51 -0400
On 08/03/2014 07:28 PM, Cédric wrote:
Le Sun, 03 Aug 2014 20:01:06 +0200, Jonathan <jonikelee AT gmail.com> a écrit:
Goal forall (A : Prop) (P : A -> Prop),
({x : A | P x} : Prop) -> ({x : A | P x} : Type).
intros A P H.
exact H.
Qed.
-- Jonathan
Well, "sig" is declared to be of type "forall A, (A -> Prop) -> Type", so it is not very surprising that a ({x : A | P x} : Prop) can be cast into a ({x : A | P x} : Type).
What could be surprising is that ({x : A | P x} : Prop) is accepted. I know that this is not a bug, as this is something known and intended, but that is so unnatural for me…
It is like promotion of the unit type to Prop. Although you declare it in Type, it lives in Prop:
Inductive unit : Type := tt.
Goal unit : Prop.
exact tt.
Qed.
Inductive bool : Type := true | false.
Goal bool : Prop.
I know that it is legit, as it contains no information, but still, that tends to make things non obvious…
I was just wondering if someone could state the rules in some consistent way, by which I mean there are no rules that appear to prevent something (destruct an uninformative ex in a non-Prop context) when actually they don't (rewrite it to a sig, then destruct it) - which just creates confusion. It would certainly be nice if the rule was simply that anything at all that contains no information can be case analyzed in any context. I would even argue that things like "False \/ P" should be case analyzable in any context - because (and, of course) it can be turned into P by use of assert, applying a lemma or a rewrite. Although, perhaps in the general case whether or not such a thing contains information isn't computable. What if there was some meta-predicate "uninformative" that one could first prove on a specific instance and then use later to case analyze that instance? Or, separate Prop into IProp (informative props, like P \/ Q) and UProp (uninformative props, like False \/ P), where Prop is the undecidably-disjoint union of those? But this is much ado about ... well ... nothing. Other than linguistic consistency.
-- Jonathan
