coq-club - Re: [Coq-Club] what exactly are the Prop analysis rules?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] what exactly are the Prop analysis rules?
  • Date: Sun, 03 Aug 2014 12:20:39 -0400
On 08/03/2014 12:02 PM, Pierre-Marie Pédrot wrote:
On 03/08/2014 17:47, Jonathan wrote:
What is so different about a nat vs. a sig that allows the analysis of
the ex H in the sig goal but not the nat goal?
This is due to a weak form of universe polymorphism of the old
inductives. In your case, the sig that usually lives in Type collapse
into Prop because all of its arguments are from Prop.
Variable A : Prop.
Variable P : A -> Prop.
Check {x : A | P x}.
{x : A | P x} : Prop
I do not know if this is documented somewhere, but this phenomenon
occurs with all inductives which do not provide a relevant content
whenever their parameters are instantiated with Prop-living types. This
is the case with one-constructor inductives, like sig, prod & eq.
PMP
So, what exactly is not being able to destruct H in the nat goal preventing, when I can just do this:
Goal forall (A : Prop) (P : A -> Prop),
(exists x, P x) -> nat.
intros A P H.
Fail destruct H.
assert ({x : A | P x}) as H' by (destruct H; eexists; exact H).
destruct H'.
I could even write a rewrite rule:
Lemma ex2sig: forall (A : Prop) (P : A -> Prop),
(exists x, P x) <-> {x : A | P x}.
intros A P.
split.
intro H. destruct H. eexists. exact H.
intro H. destruct H. eexists. exact p.
Qed.
Require Setoid.
intros A P H.
Fail destruct H.
rewrite ex2sig in H.
destruct H.
Abort.
-- Jonathan
